Paul and Pippa
I've posted about repairing my own bumper before but just found out it's ABS plastic,,any advice would be much appreciated..
I contacted Dethleffs and they said it was ABS..apparently what l saw, on utube its the same material as lego..I'd be interested too - So many different plastics and many of which will not glue successfully.
I have managed to stick strips of curtain rail (similar plastic) to my bumper cracks but still not 100%
Saw a video on utube, said ABS is the same material as lego.. And said it can be melted down to use as a repair.I'd be interested too - So many different plastics and many of which will not glue successfully.
That's very helpful, thank youNearly if not all plastic products are stamped with info including what type of plastic it is. This allows plastic welders to select the correct rod to repair cracks and splits.
These folk supply all the equipment for plastic welding
https://www.welwyntoolgroup.com/plastic-welding/plastic-welding-hand-tools
whilst it’s probably not worth buying for one job, you can Google plastic welding around your location and you should find someone not too far away with the equipment.
Thank youTry a repair kit called plast-aid, it can be found on Amazon
YouTube has info for self repairs. plumbers glue for ABS thickened with scrap pipes is suggested. i have some but not brave enough to try it yet. white Gorilla make duct tape covers it well enough for now.
[/QUOTE. I've got duct tape on now,, lol.. I'm fed up with people going past saying.. Ohhhh look he's had a bump lol..l will try and repair it myself after taking on board all the advice. May be better than paying out almost £1000,,
Thanks that sounds Brill, l thought about using fibreglass but was unsure if it binds with abs,, also l think like you l can do it while still attached to the MH,, my estimate was almost £1000 for the back right end bumper and a skirtingI had exactly the same problem last year. New corner section was about £250 plus painting plus vat etc so I thought what the hell what have I got to lose. The perfectionists here may not agree but it worked for me.
Either remove panel and work on a bench I was lucky I could do repair in situ from underneath Ive got a Swift. Using a Bremel with a fine grinding disc very slightly and gently widen the crack grooves from the inside, then about 1/2 inch away from the cracks drill a few tiny holes about 1/8 dia. I had a few small fragments so I put them together on the bench using super glue to hold them together in 1 piece temporary and inserted it into position from underneath
Here is the expensive bit go to Halfords and buy a fibreglass repair kit about £8. Apply several lays of matting/resin from the inside, the holes you drilled act as extra anchors. Use a 4 pint milk container cut it into a flat square and fix it to outside edge with masking tape you can use a little heat ( gently does it ) to mould the container to the contour of the panel. The beauty of this trick is fibreglass resin will not adhere to this type of plastic.
Finish off outside with abs filler also from halfords. The most important thing is to use flexible primer as normal primer will crack as the panel flexes. The biggest problem I had was matching the paint. MH seem to have exclusive paint colours I was lucky it turned out to be a RAL colour.
Like I said I tried this, it had 2 chances and up to now its lasted over 12 months no sign of cracks total cost of about £50. Worse case scenario new panel nothing ventured nothing gained.
It's really expensive just to buy a replacement, and then l would have to cut holes for lights and the decorative stickers and painting.. Sooner have a go myself. ?Funny old stuff this ABS thats why I suggest drilling the holes for that extra bit of grip. The other option is to remove it and take it to a bumper repair place. Cost you more than £50 though.
Hahahaaaa.,,,cheers..?good luck like I said nothing ventured nothing gained depends if you are perfectionist like my old boss said you cant see it at 30mph or only go out in the dark
That's a good idea, thank youI did mine a few years back using a soldering iron and strips from a replacement half bumper from ebay.
Repairing my rear bumper.
