Ah OK - at 1700N struts will be lethal if they are not clamped in the closed position or fully extended when removed. I would use a suspension spring compressor to clamp the old unit but I'm a bit stupid at times so don't take my advice unless you're really happy that the compressor won't slip offYep, thanks. SGS are brilliant and have a direct replacement in stock, very reasonable prices.
The Problem is how to change them. See my post in the Technical forum asking for views / comments ?
They're normally extremely easy and safe to change. With the bed in the most convenient position for access loosen the fixing nuts for the strut ends until they are finger tight, or if applicable, remove split pins. Park the bed fully up and attach any safety straps if provided. Prop the bed slightly higher than 'up' to take the weight off the struts. Use a length of 3 x 2 as a prop from the floor. Use a scrap of board or plywood padded suitably to spead the load on the underside of the bed.Ah OK - at 1700N struts will be lethal if they are not clamped in the closed position or fully extended when removed. I would use a suspension spring compressor to clamp the old unit but I'm a bit stupid at times so don't take my advice unless you're really happy that the compressor won't slip off
Replace the struts. Wiggling and/or prop adjustment will be needed to enable the pins or bolts to be removed. A helper who understands what you are doing is very useful for the wiggling operation. Push the pins into place through the new struts then remove your prop and set the bed in a position where you can access the pins / bolts to complete the operation.
At no time will you be working with the struts compressed. Depending on what's in the way you may have trim to remove but so far I've managed a couple of different vans by working from the cab and from outside via the side windows or door(s).
Certainly not identical but with similar access problems. It is essential to remove nuts, etc, with the bed in any position that makes them accessible so the only thing left to do with the bed up & struts extended is the actual strut removal / replacement. I would be surprised if there wasn't room in the sandwiched area to remove the nut and, when it's extended, remove the strut. If the sandwich is created by bolted sections it might be necessary to slacken more fasteners & wedge the sandwich more apart. My current van has a one-piece moulded under-bed section but it can be removed.Tony, thanks for taking the trouble to give such good information. BUT the problem I have, is even with the bed fully raised (with the safety strap as tight as it will go) there is no way you could get your arms / hands in the side gap to wiggle the struts off there bolts / pins. (the whole of the underside of the bed is encased in a grp moulding which I cannot be removed in order to provide any 'through the base' access)
Also the shaft end lug is sandwiched in the bracket arrangement, which looks like it will be really difficult to get off ? unlike the cylinder end which is a normal bolt arrangement.
I stand to be corrected if this is the sort of access you have worked with on the replacements you have done (& salute you ! )
There's more detail and some more photo's on the Post I put under Technical.
This is a pic of the shaft end lug. + the access when the bed is fully raised.
I've just had a look at your other pics. The arrangement is similar to mine. I understand the difficulties and because it's difficult I'd be unlikely to trust anyone but the owner to do the job - there's just too much potential for ham-fisted damage
