50 watt fan
Spade
dethleffs
Still a newbie
Hi.
My battery setup is 2 110ah batteries and 80 watt solar.
I have a 1500 watt inverter that I have never needed to use as all my electronics are 12v or USB.
But I have found a 220v fan which is 50w which I would like to use through the inverter.
Would it be a big electrical draw if left on overnight during the hot night's
Thanks for any info
Using without hook up just to clarify
if lead acid batteries you have half capacity so 110 ah if lithium you have pretty much full capacity
50 watts to ah usage can be converted here very little to worry about, dont forget to add the inverter usage
Hi.
Thanks for any info
Roughly 5a draw from your batteries. Your batteries have roughly 100ah usuable so will run it for 20 hours, if youre not running anything else. Overnight say 8 hours will be 40ah which will take your panel at least 10 hours of full sun to replace.
