D
DM14742
I was happily trundling along the M42 the other day when to my horror the fuel gauge suddenly dropped from three quarters full to empty with the flashing warning light giving it big licks. My first thought was a catastrophic leak from the fuel tank but there was no sign of anything untoward in my mirrors and the Van was happily continuing along with no other symptoms.
I stopped soon after to check things out but couldn't see anything, I fired the Van up again and low and behold the gauge worked, well it did for a while and then the same thing happened. To cut a long story short I am getting a range of readings on the gauge varying between what I believe is the correct fuel level, occasionally it shows obviously incorrect contents on the low side and progressively more occasions when it's showing totally empty.
Does anyone know if the fuel tank has a float inside that might be sticking or any other ideas would be welcome.
Thanks in advance
Edit: it seems okay initially (from cold) but gets progressively worse the longer the drive.
Thanks in advance
