2008 Argos 747/748 Gaslow
Spawn_e_git
Norfolk, UK
Burstner Argos 748
4 years
Hi.
as above models , will the gas locker fit two 11kg gaslow bottles.
see lots of pictures of them with two bottles inside but cannot see if they are 11kg or 6kg.
thanks
have you considered an underslung tank?
I think that would be overkill for me. just wondering if I can fit two 11kg in case we go skiing or a longer trip. I currently use Flo Gas as it's cheaper but harder to get hold of.
Measure your space
What are the dimensions of the Direct Fill cylinder?
  • Small Gaslow 2.7kg cylinder is 330mm high and 202mm in diameter
  • Medium Gaslow 6kg cylinder is 460mm high and 246mm in diameter
  • Large Gaslow 11kg cylinder is 560mm high and 304mm in diameter
you might find the difference in price isn't that much, it also frees up another locker, which might be helpful if going skiing to store wet boots etc? an advantage to having cylinders though is that they can be transferred to a new van at some point
Measure your space
I am waiting to collect the Van so not sure of the locker dimensions. also the door will be smaller so it might not be that simple
My door is small but i have a 6kg and an 11kg get the 11kg in and then the 6kg but i cant fit 2 x 11kg in
Is this on an 07> Argos 747/748?
No but the locker doors do seem small on vans but you get the height inside the locker normally my last van different make would take an 11kg and a 6kg not enough space for 2 x 11kg bottles - I put the sizes up because i thought you had van already and it is easier to measure the space - but i've not had 1 of those vans so dont know sorry
