2004 AutoTrail Cheyenne- anyone replaced the door hinge fixings of, & the surround to, the external gas locker & the retaining clip to keep door open? (1 Viewer)
MH04RMV
84
151
Cheyenne 632 SE
Hello Everyone,
I'm needing to replace the fixings of the hinges to the gas locker door - primarily because previous owner has used a couple of screws that are as much use as a chocolate tea pot (they just pull out), and some bolts that would make Frankenstein proud.
Problem is, it seems that there was once a strip of 3-ply behind the hinge holes that has rotted, so nothing solid to screw anything in to/use to distribute the door weight.
Has anyone taken the locker surround off/out, to replace the wood, or replaced the whole thing?
While it's out, I could also add some extra fibreglass repairs to strengthen the sills.
In addition to the hinge issue, the male/female clip and holder to keep the door open need to be replaced as worn out - what fixings can be used for the "female/holder part, that fixes into the main body?
I've tried replacing the pop-rivets, but it looks like the originals have partially pulled out the aluminium skin, so can't get any that are wide/fat enough to hold in place (the mini polystyrene balls insulation doesn't help either).
I did try a generous coating of some Sikaflex, but that pulled off straight away when door was temporarily fixed to it may 😤
What could be used?
Appreciate any thoughts/suggestions.
Cheers,
Rich.
Nov 5, 2013
2,897
92,533
Shropshire
Carthago chic e-line
Since 2013
Have you tried using split/load bearing/tri fold rivets ?
I seem to remember our locker door had one of these catches on
Amazon product
M
MH04RMV
84
151
Cheyenne 632 SE
Hi rb62,
Yep, that's the type of catch it has which I've got some replacements for.
Nope, not tried that type of rivet - will look out for some, thank you.
Cheers,
Rich.
