1999 B640 (Merc) exhaust
By centre exit, do you mean underneath the van in the middle, or that it comes out of the back of the van but in the middle.
I still find it hard to believe any manufacturer would exit half way down and in the middle of the van. Unless it is a new van it may be someone did not fit a full or correct system. Due to the Alko chassis a standard Peugeot Boxer van system would not fit hence getting a custom stainless system made up.
Of course I have been wrong many times in life.
I have just double checked my PSV MOT testers manual circa 1999 and on page 46 it reinforces my belief that when I operated Coaches, ALL exhausts HAD to exit on either the rear or the offside of the vehicle.
If they do not, it is a MOT failure!
I would suggest that, although it's an old manual and only applies to Passenger Service Vehicles, the same would be true of Motorhomes?
(With most Motorhomes being manufactured abroad, perhaps the offside reference maybe questioned but I'm sure the exit outside the line of the body still exists.)
IMO, it would make sense? 🤔
Reactions: 68c
Correct for psv but not to my knowledge class 4,or class 7 or lgv /hgv,as with many things on psv somewhat ott. ( How long would vehicle have to be stationary with engine running in perfect wind conditions before exhaust gas became noticeable let alone dangerous)I seem to remember in the early 70s Merc were the first I saw and apparently still do it ..outlet I believe was toward road surface ctr saved lhd & rhd having different systems
Hopefully, with Cats and DPF's, NO Buses or Coaches will have 'noticeable' exhaust gases?
I know mine didn't and they often were standing for long periods in London traffic.
By the way, I'm pretty sure that the ruling I mentioned, has been in force for a number of decades.
You say that PSV vehicles are OTT but, can you name ANY vehicle designed in the last 25 years that does NOT have it's exhaust ending either at the rear or side or up in the air (trucks), I can't! 🤔
Reactions: 68c
My hymer use to have a exhaust that did not exit to the side but pointed down to the ground. I used to get some black carbon sometimes in the van nothing serious just a bit of black near vents. When the time came to replace I had a stainless steel one made which now exits to the side no problems since
Todays experiment will be reintroducing the sealed cell link in the solar controller which drops the absorption voltage from 14.6 to 14.1 and does away with equalising voltage, fingers crossed the batteries aren't cooked with a capital F :-)
Well, all seems well so far, a much healthier 13.8v from the solar controller and no egg smell with the engine running and solar connected together, disconnected batteries read around 12.8v so fingers crossed no permanent damage. I do believe that also when the batteries where replaced the solar panel was left connected so its likely the solar controller got its knickers in a twist (especially if it was a sunny day) and the system has never truly been tested with the new batteries due to the MH being sorn and on EHU on a driveway for 6 months, only time and my next longish drive will tell. If not its a single 100ah sealed replacement battery as ive read the EBL 104-3 doesnt like a dual battery set up (replacing 2 x 85ah sealed batteries) and a Votronic MPP 165 install.
Update, replaced the failing solar charger that today was trying to put almost 19v In to a pair of 85ah LA batteries with one purchased 2nd hand off here. Went back a couple of hours later, both batteries now sitting at 13.6v and the solar controller (truma sd10) is happily blinking to say that the batteries are fully charged. Hopefully the "overcharged" batteries have no lasting damage as they are no longer gassing and seems to hold charge ok when disconnected, purchased a 90ah spare just in case but I'm happy I've got to the bottom of it.
Mornin, the exhaust on my 5 pot 2.9 diesel exits slap bang in the middle of the hab area along the centre line, approx directly under the lounge area, is this normal or has the exhaust been shortened. I have a thermostat issue at the moment meaning the cat stinks as it never really gets to full temperature and while driving the interior of the MH stinks of eggs. Now I know I need to fix the underlying issue (the thermostat isade of unobtanium and is stupidly expensive) bit surely the exhaust should exit out of the side of the MH or the extreme rear?
I was under the impression that Merc didn't fit dpf's until 2006, CAT's being fitted to petrol engines a bit earlier, perhaps someone can clarify that.
