16A Mains Outlet (1 Viewer)
tuscancouple
552
964
Kent
Hello, does anyone have a suggestion where I can purhase a 16A (blue) mains outlet, preferably angled and water proof to fix outside the house so that I can plug the RV into it?
Lynda?
Mick
2,334
10,102
Hi Mick
Here is one from Farnell
Whatever you buy make sure it is IP 67 rated.. (that's waterproof) .
Digger Driver
578
4
Lancashire
You could try your local small tool plant hire shops!
I got some of my fittings at one!
HSS Hire!
Speedy plant hire!
Hewden plant hire!
These are a few off the top of my head!
If they don't stock what you want they should be able to point you in the right direction!
Phil
226
Herts
10 years
Caravan Accessory shops usually sell them.
tuscancouple
tuscancouple
552
964
Kent
thanks for the suggestions. After a dummy run with a 32A socket I now have the correct 16A one. Well the 32A one looked correct, had a blue top just a little on the large side! ::bigsmile:
Mick
