- won’t be on EHU and need a 12v to 2x3pin adaptor ?
I'm assuming a mains inverter with two 13A sockets to plug in the laptop charger and monitor.
Sorry that is correctI'm assuming a mains inverter with two 13A sockets to plug in the laptop charger and monitor.
For my laptop I use a cigarette 12v to 19v basic adaptor, no problem just get the right one for the laptop.
From the solar panel and frugal use - don’t intend to work that muchProbably cheaper buying a single output inverter and use a two gang extension lead.
As said, a pure sine wave inverter or you could damage both the laptop and monitor
It's a lot of money for very limited use.
Don't forget, whatever you take out of the battery needs putting back in.
With no hookup how will you recharge the battery ?
Ours has a remote lead &switch fitted which is easy accessible in the MH , loads of inverters have the option to install a remote switch , as yes if left on just idle ours uses about 1amp which can sure add up if left on 24/7What do people use to isolate the inverter from the 12v feed when not in use? I am talking about when you have it connected via some chunky leads. I would like to install an inverter but only have limited requirement, so I dont really want a continual drain all the time.
Trevor I think it might come with a 12v supply , looks like a tidy TV , nearly tempted to upgrade oursHow about one of these ..
Broken Link Removed
and one of these?
Amazon product ASIN B07W5DD6M9
.. saves jacking it up to 240v then back down again.
Yep, I saw that - already got a 12v TV, else I'd be having one.Trevor I think it might come with a 12v supply , looks like a tidy TV , nearly tempted to upgrade ours
