X250 fuses (1 Viewer)
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Would it be possible for someone to take a picture of the pages in their ducato handbook covering fuses... I only have a French handbook.. and my French is pretty poor.
In my book it's pages 178-184.
::bigsmile:
Dec 6, 2011
11,589
25,418
South Wales
Coach built Adria
this x250 2012 handbook:-
Dec 6, 2011
11,589
25,418
South Wales
Coach built Adria
last 2 pages'
TheBig1
17,630
43,277
why dont you download your handbook? its free
Link Removed
just need to register for free and then you can download it and check if theres any recalls outstanding for your van etc
TheBig1
17,630
43,277
forgot to say, earlier versions in all languages are available from here
Broken Link Removed
sdc77
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Phill.. Thanks very much for your help.. They were too small though.. TheBig1 many thanks for the link.. Am getting it from there.. Cheers::bigsmile:
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Link Removed
Looks really useful - how on earth do you get registration to work? I keep getting an error message "To register you must give your consent" underneath "Do you accept the terms of the Privacy Policy". I've tried both check boxes and done the same with the Newsletter option. Just doesn't work.
sdc77
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Make sure you did the password thing correctly.. Needs a capital and a number
TheBig1
17,630
43,277
its a long time since i registered on the site so don't recall all the details but do know they are very fussy about passwords having both upper and lower case letters and some numbers. once registered go to the email you used and click on the confirmation link in the mail from fiat
then it will let you log in
if it still gets stuck, pm me an email address and i will forward a copy as an attachment or could use my dropbox account
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
I finally made it. The error message I mentioned seems to appear whatever is causing the problem. In my case I was trying to use a username with a 'dot' in it - which isn't allowed.
Thanks for the offer of help though. :Smile:
sdc77
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
So.. Can anyone tell me which fuse/relay would control [HI]brake lights only on trailer only[/HI]
It doesn't leap of at me from the manual
Dec 6, 2011
11,589
25,418
South Wales
Coach built Adria
not sure this helps but main brake light control is F37 7.5 amp
r/h side of dash under cover top row, 4th from left
Dec 6, 2011
11,589
25,418
South Wales
Coach built Adria
not sure what you mean " trailer only"!
if its for your tow bar electrics that may be a retro fit with the tow bar and could be anywhere
TheBig1
17,630
43,277
the trailer doesnt have a separate fuse in the fuse box. as i said on the other thread, it will depend which way the trailer is wired, theres 2 options
option 1, the trailer is wired into the harness using a dedicated wiring kit. in this case, the body ecu will detect a short circuit and turn off the feed to the trailer lights to protect the rest of the system. fix the fault and then disconnect the battery to reset the ecu. if it still wont work, it will need plugging into the fiat computer to reset it
option 2 and more likely is that a bypass relay has been wired into the van lights. this hides the extra bulbs from the ecu so it wont see extra bulbs as a fault. it draws power from a fused feed from the battery. if the other light are working, the fuse is fine. if the wiring develops a short circuit on one of the relay outputs, indicators, lights or brake, then it will either blow the fuse killing all lights to the trailer or burn out that part of the relay. you will need to fit a replacement bypass relay to fix the fault
Broken Link Removed
this explains bypass relays
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
Are you certain that nothing is coming out of the trailer socket on the van on the brakelight pin?
sdc77
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Well.. I don't have a socket tester.. But I have a trailer with lights and a separate light board. Tried them both and neither have brake lights.. All other lights work.
Am going g to try and figure it out this weekend one way or another
sdc77
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Broken Link Removed
OK.. Seems I have the ring automotive Canbus multiplex relay.. It has an onboard red led that's on. I did disconnect it for a while.. No difference though.. Still no brake lights to trailer... Ill order a replacement..
Thanks very much for your help thebig1 and anyone else that offered advice
