Wireless reversing camera (1 Viewer)
jabbaman1
70
6
Glasgow
coachbuilt
Since 2006
Hi,I bought 7 inch wireless reverse camera ,does any one have a preferred way of wiring them ,I was going to take a feed of the reverse light for camera ,and one of the ignition or gigarêtte lighter for the monitor ,any views would grateful,Thanks jabbaman:Doh:::Smile:
Jaws
23,836
72,493
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I personally prefer the camera to be on whilst travelling so I can see what is going on behind me at all times.. I wired my camera(s ) to the 12v feed to the fridge so they only come on when the ignition is on..
Only pitfall I have ever had using wireless is when you get close to someone with a more powerful camera .. Most memorable was when the motorcycle trailer suddenly became a speed boat whilst on a German autobahn !! Took me a good couple of seconds to realise what was happening :Doh: ( and it is surprising how many times this has happened... Even got a picture of a childs cot once when sitting in traffic in a town ::bigsmile: )
jabbaman1
jabbaman1
70
6
Glasgow
coachbuilt
Since 2006
Thanks for reply,sounds like good advice,dont fancy the confusion on the monitor that would have freaked me out,cheersAndy:roflmto::roflmto::roflmto::roflmto::roflmto::winky::thumb:
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
wireless cameras were designed for cars and not motorhomes as already said stronger signals can give you an incorrect signal, they can in some cases remove a picture altogether. I don't know anyone with one still fitted to a motorhome as they tend to be replaced with fully wired ones PDQ. Lots of info in other threads, you only have to look.
Anyway good luck you could always relegate it to being an internal cam just to check on what is flying around when you hear a noise behind you, hee hee.
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
I had a wireless one on my last van. They do suffer from interference and on one occasion I had my rear view briefly replaced by someone's video. I'd get a wired one if I was you.
dennismartin
135
19
hull
c class
im a newbie
never had any problems with mine
wired to ignition
Jaws
23,836
72,493
Thetford Norfolk
C class, Chieftain
Surely running a wire right from the front to the back somewhat defeats the object of having a wireless camera ?
Jaws
23,836
72,493
Thetford Norfolk
C class, Chieftain
If you have a multimeter, you can find the feed to the fridge easy enough :Smile:
Remove the lower vent and all the wiring will be right in front of you.
Often, builders use a yellow wire to feed the unit.. Whatever the colour it will be a fairly thick wire going to a con block.
Start the van and check all the feeds going to the fridge
Turn the van off and check again.. One will proly remain live ( that one usually feeds the fridge light ) but the other will be dead.
Hook up the camera live to the one that went dead when the ignition went off.. The earth can go pretty much anywhere but if you are running a 'pair' from the camera you might as well use the fridge earth for that at the same time :thumb:
quarryjmiller
41
22
Hereford
Low profile
Since 2006
Digital wireless cameras
Most wireless cameras are quite badly prone to interference but there are some excellent digital cameras out there that are used in the construction industry which do not suffer with interference, have a look at this website:
Link Removed
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
i can just imagine driving past someones house and getting 70's porn :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
dysdera
8
6
hampshire
Hi top
newbiw
live feed
IU took mine from the sidelight feed....then it reminds me to switch on my sidelights to see out the back.
