Winter battery charging (1 Viewer)
David Parkes
27
Shropshire
Coach built
Hi everyone out there lets here all your ideas about trickle charging vehicle battery's during winter I have an efoy leisure battery charging system is it possible to charge the vehicle battery from an on board charger or if I hook up to the mains can you back charge.
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I use and have used several battery maintenance module from C.A.K. Tanks.. £27 and a ten minute fit
BUT !
I would suggest you give them a ring cos they are often out of stock as they are so bloody popular !! ( 01926 854271 )
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
wouldn't a temporary link wire connecting both battery sets work ???????-------that would be cheap/easy-------Or a permanent one with a switch ???
Nigel & Pamala
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Nigel & Pamala
yes a link across the terminals of thesplit charge relay will work it should contain a low amp fuse to blow if you accidently start the van with the link in place which would be detrimental to the leisure battery
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
remember in Zahora Nigel ::bigsmile:
What I borrowed one of your jump leads for to help out a young lady who was feeling a little flat !! :Eeek:
