Windscreen scratches (1 Viewer)
Mar 16, 2010
3,057
30,810
Carmarthenshire
In between
Since 1988
Any recommendations for getting scratches off the windscreen?
Previous owner of our autotrail must have used wipers when the rubber was perished and it has left an arc scratch across windscreen.:Angry:
Nov 6, 2008
3,944
40,801
Ramsey, Isle of Man.
Coachmen Concord 300TS
8 years with an RV
If they are deep, you have no choice, new glass. Also it will fail an MOT if it's bad.
RV-less Craig
43,337
49,538
even light scratches in glass will be permanent and a probable MOT failure.
£50/£75 excess is a small price to pay for a new screen worth many hundreds and doesnt usually affect your no claims bonus.
eric 83
87
46
leeds
30+yrs
Jewellers ruge will do it but if they are scratches as apposed to scuffs they will not come out, but you can reduce them! trouble is the sun allways shows them up.
17,635
43,369
if it only a minor scratch
use "whitening" toothpaste and a cloth
1 wet the window area with water from a spray bottle
2 squeeze out some toothpaste onto the scratch
3 rub with a microfibre cloth in a circulare motion, or a polishing machine on medium setting. if done by hand it will take some serious buffing
4 wet occasionally and apply more paste as needed
5 wash area and close bodywork thouroghly when done
use whitening toothpaste as it has a higher and coarser abrasive content
deeper scratches are impossible to remove
Jamwitt
630
367
Chandlersford
4yrs
Scratches moor then likely caused by ice scraper had them on my new car :cry: you will not get them out as the glass is toughened
17,635
43,369
if you can scratch glass with a plastic scraper, then its not that hard. on the other hand though, if caused by a small stone / bit of grit on the wiper then these are extremely hard to fix.
basically you need something harder than glass to scratch it and again as an abrasive to polish scratches out. deep scratches mean you would have to polish away more glass to make it flat again making it much harder to do and impractical
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
A friend of ours who worked in a jewelers suggested braso , never tried it on my scratchcaused by the wiper arm has we sold the MH,worth a try. Pete
Xan
158
102
Bristol
I'm new
You may also find Duraglit wadding helps.
You can start with a coarse mix buy dipping the wadding into a some bicarbonate of soda.
Then go finer using Duraglit alone.
Duraglit is also useful for removing scratches from plastic. I've even used it successfully on ski goggle lenses.
