Windscreen scratches
Discussion in 'Motorhome Chat' started by davanne, Oct 13, 2012.
  1. davanne
    davanne Funster
    Mar 16, 2010
    1,377
    7,372
    Carmarthenshire
    Any recommendations for getting scratches off the windscreen?
    Previous owner of our autotrail must have used wipers when the rubber was perished and it has left an arc scratch across windscreen.:Angry:
  2. simsy56
    simsy56 Funster
    Nov 6, 2008
    3,066
    13,087
    Ramsey, Isle of Man.
    If they are deep, you have no choice, new glass. Also it will fail an MOT if it's bad.
    RV-less Craig
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,912
    17,579
    YO11 2BD
    even light scratches in glass will be permanent and a probable MOT failure.
    £50/£75 excess is a small price to pay for a new screen worth many hundreds and doesnt usually affect your no claims bonus.
  4. davanne
    davanne Funster
    Mar 16, 2010
    1,377
    7,372
    Carmarthenshire
    Just passed m.o.t. Only noticeable when the sun shines on windscreen.
  5. pappajohn
    Aug 26, 2007
    29,912
    17,579
    YO11 2BD
    in that case, if you can live with it then leave it as is.
  6. eric 83
    eric 83 Read Only Funster
    Jan 6, 2009
    90
    46
    leeds
    Jewellers ruge will do it but if they are scratches as apposed to scuffs they will not come out, but you can reduce them! trouble is the sun allways shows them up.
  7. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,526
    9,947
    if it only a minor scratch
    use "whitening" toothpaste and a cloth
    1 wet the window area with water from a spray bottle
    2 squeeze out some toothpaste onto the scratch
    3 rub with a microfibre cloth in a circulare motion, or a polishing machine on medium setting. if done by hand it will take some serious buffing
    4 wet occasionally and apply more paste as needed
    5 wash area and close bodywork thouroghly when done
    use whitening toothpaste as it has a higher and coarser abrasive content
    deeper scratches are impossible to remove
    • Like Like x 1
  8. Jamwitt
    Jamwitt Funster Life Member
    Jun 18, 2012
    504
    243
    Chandlersford
    Scratches moor then likely caused by ice scraper had them on my new car :cry: you will not get them out as the glass is toughened
  9. TheBig1
    Nov 27, 2011
    7,526
    9,947
    if you can scratch glass with a plastic scraper, then its not that hard. on the other hand though, if caused by a small stone / bit of grit on the wiper then these are extremely hard to fix.
    basically you need something harder than glass to scratch it and again as an abrasive to polish scratches out. deep scratches mean you would have to polish away more glass to make it flat again making it much harder to do and impractical
  10. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    A friend of ours who worked in a jewelers suggested braso , never tried it on my scratchcaused by the wiper arm has we sold the MH,worth a try. Pete
  11. Xan
    Xan Read Only Funster
    Sep 25, 2012
    160
    104
    Bristol
    You may also find Duraglit wadding helps.
    You can start with a coarse mix buy dipping the wadding into a some bicarbonate of soda.
    Then go finer using Duraglit alone.
    Duraglit is also useful for removing scratches from plastic. I've even used it successfully on ski goggle lenses.
