Why no British channels? Oyster 85 dish. (1 Viewer)
Norman Jones
299
286
Nr Aberystwyth
A class, Hymer 620 mli
since 1982
When on tour in Europe we are used to receiving 200 German channels and 2 English News channels. But why the heck am I still only receiving all these foreign ones at home in Wales, it's driving me nuts.
43,337
49,540
Possibly tuned to Astra 1.
Mostly German channels I believe.
Very close to astra 2 in orbit so easy to lock on the wrong one.
18,036
48,148
You can get SC4 on satellite? :)
But if your dish is still pointing at the satellite it was when in Europe, which it will if possible, you will get exactly the same channels.
D
Deleted member 29692
Probably locking on to the wrong satellite or possibly the wrong transponder. Make sure you're on Astra 2 at 28.2 degrees.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
It sounds as though your Oyster is still pointing at the Astra 1 position (19.2° East of South) instead of the Astra 2 cluster (28.2° East of South).
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
That means you are in the wrong satellite as that's Astra 1 ( German ) and not Astra 2 at 28.2 degrees ( English ). I would suggest you check settings in the user menu of your system. It may need updating.
mariner
1,283
3,778
Isle of Dogs, but mostly Artola Spain.
Caravan
Since 2007. But no more.
My guess is that your on Astra1 @19.2 East. You need to reset your dish manually onto Astra 28.2 East, then put it in the memory.
Or you could just use Freeview through a normal TV Ariel!
:cooler:
Don Quixote
2,966
5,258
VW T6 Campervan
:cooler:
Why would he manual tune when the system is automatic!
Don Quixote
2,966
5,258
VW T6 Campervan
Norman Jones
Norman Jones
299
286
Nr Aberystwyth
since 1982
Yes it is going to 19.2, but when I switch it to 28.2 I get NOWT. Must be too many B trees & hills at home !Seems the answer is a chainsaw!
mariner
1,283
3,778
Caravan
Because the system locks onto Transponders entered into the system memory, so if Astra 28.2 isn't in the memory, you have to put it in yourself.
I am assuming that the poster has checked the memory for Astra 28.2.
The system I had, allowed up to 4 Transponders in the memory.
:cooler:
