Why no British channels? Oyster 85 dish.
Discussion in 'TV & Satellite' started by Norman Jones, Feb 5, 2016.
  1. Norman Jones
    Norman Jones Funster
    Jan 13, 2015
    72
    42
    Nr Aberystwyth
    When on tour in Europe we are used to receiving 200 German channels and 2 English News channels. But why the heck am I still only receiving all these foreign ones at home in Wales, it's driving me nuts.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,946
    17,612
    YO11 2BD
    Possibly tuned to Astra 1.
    Mostly German channels I believe.
    Very close to astra 2 in orbit so easy to lock on the wrong one.
  3. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,764
    11,965
    Plympton, Devon
    You can get SC4 on satellite? :)
    But if your dish is still pointing at the satellite it was when in Europe, which it will if possible, you will get exactly the same channels.
  4. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,768
    11,822
    Kettering
    Probably locking on to the wrong satellite or possibly the wrong transponder. Make sure you're on Astra 2 at 28.2 degrees.
  5. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,852
    1,908
    Warwickshire
    It sounds as though your Oyster is still pointing at the Astra 1 position (19.2° East of South) instead of the Astra 2 cluster (28.2° East of South).
  6. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,507
    3,711
    Lost in La Mancha, Spain
    That means you are in the wrong satellite as that's Astra 1 ( German ) and not Astra 2 at 28.2 degrees ( English ). I would suggest you check settings in the user menu of your system. It may need updating.
  7. mariner
    mariner Funster Life Member
    Nov 21, 2013
    1,284
    3,798
    Isle of Dogs, but mostly Artola Spain.
    My guess is that your on Astra1 @19.2 East. You need to reset your dish manually onto Astra 28.2 East, then put it in the memory.
    Or you could just use Freeview through a normal TV Ariel!
    :cooler:
  8. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,507
    3,711
    Why would he manual tune when the system is automatic!
  9. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,507
    3,711
    Try here as I think your software may be outdated:
    http://blog.conrad-anderson.co.uk/?tag=oyster-satellite-problems
  10. Norman Jones
    Jan 13, 2015
    72
    42
    Nr Aberystwyth
    Yes it is going to 19.2, but when I switch it to 28.2 I get NOWT. Must be too many B trees & hills at home !Seems the answer is a chainsaw!
  11. mariner
    Nov 21, 2013
    1,284
    3,798
    Because the system locks onto Transponders entered into the system memory, so if Astra 28.2 isn't in the memory, you have to put it in yourself.
    I am assuming that the poster has checked the memory for Astra 28.2.
    The system I had, allowed up to 4 Transponders in the memory.
    :cooler:
  12. mariner
    Nov 21, 2013
    1,284
    3,798
  13. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,507
    3,711
