Who's a silly RVer then (1 Viewer)
joncris
1,101
1,603
Where it matters
Rimor Katamarano 12p +
ME :Blush: I pitched on a commercial site & connected my water direct to the mains WITHOUT checking I had a pressure valve fitted:Doh: Needless to say I didn't & the pressure blew the shower pipes apart causing water to p*** out of the near side. Result panic:Eeek: turned off water used jacks to lift van to left so that any water would drain out AND it worked:whatthe: no smelly carpets etc
Have now reconnected internal pipes AND purchased a pressure valve:thumb:
Pusser
188
192
Bucks
A week away
On and off 1981
You could have been the first proud RV owner to have a bidet although with that pressure you may have shot out the roof vent.
Jim
Ringleader
Jul 19, 2007
36,421
130,919
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I hooked up to city water a few times without a pressure valve; didn't know that I needed one :Doh:luckily I had my error pointed out before any pipes burst. Hope you've dried out nicely:thumb:
RVfulltimer
28
Hi i did the same but blew the seals in the water pump not just once but twice doh
Havewheelswilltravel
19
3
Farnham
American RV A class
God 1st a Bedford when the wheel was invented
Glad you have it sorted and dried out.
I know what panic you must have had, I had filled up and switched on water pump heard a funny sound then noted pump was running without a tap on bloody connector at back of shower split and came off. So I just look at it as a learning curve and laugh about it now.
Alan
RVfulltimer
28
My friend flooded our toilet area ,he flushed the toilet and the pedal stuck down he not being an rv owner thought that it stopped flushing on its own only realised when after a few minutes i could still hear the pump running and water coming under the toilet door .
Jul 29, 2007
6,551
39,656
Ipswich
RV and PVC
30 years
I have a gauge fitted on mine, but I have never seen it go over about 3bar. (45psi) their must be some serious pressures about. :Smile:
Ian
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Ian
From your picture it looks like you have a pressure reducing valve, and your pressure gauge is on the other side of it from the mains water. I could be wrong of course.
43,329
49,445
thats where it should be :thumb:
to check the pressure between the reducer and 'house' pipework....put it on the mains side and it'll only tell you what the mains pressure is.
Jul 29, 2007
6,551
39,656
Ipswich
RV and PVC
30 years
If you look at the picture its redlined at 5bar (75psi) seeing as I have never altered the valve I presume that's what its set to. If I come across a supply that powerful I will reduce it down to around 4 bar.
Ian
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
And I now realise this another thing I know absolutely nothing about :Sad: so will add it to the list of things I have to learn about!!!
Pusser
188
192
Bucks
A week away
On and off 1981
I saved myself years of work by making a list of things I do know about. :Cool:
....took a fair few minutes even so. :Sad:
