which/what oil? (1 Viewer)
LucyCaitlynW
68
78
Kent
Ford Golden Eagle Transit
I'm a newbie of 2 days
A friend has offered to change the oil on my mh for me but I've no idea
which one :Blush:
Mh is a Fiat based Golden Eagle (no handbook) 21' long though don't know if that makes a difference :RollEyes:
21 years old this year.
Also I know lots of posts regarding weight/tyre pressure on this forum but as I am numerically dyslexic it's an alien language :Sad:
Would be very grateful for advice on oil and idiot guide to tyre pressure :Doh:
Many thanks :Smile:
TheBig1
17,630
43,279
choose the brand name oil though as not all oils are the same quality. was talking to somebody recently who does their own servicing and has been using cheap oils. loads of issues with engine noise and the end result was a worn engine needing expensive and time consuming repairs. he had been using some chinese brand of probably recycled oil at half the price to purchase but at a high cost
LucyCaitlynW
LucyCaitlynW
68
78
Kent
Go to eurocarparts website enter your registration number then select engine oil. It will come up with what is suitable. You only need to know the viscosity etc then buy what make you like from where ever
http://www.eurocarparts.com/
Many thanks for this, appreciate the help.
Simple when you know what to do :Smile:
LucyCaitlynW
LucyCaitlynW
68
78
Kent
Thanks for the advice.
I'll get a decent brand name, no point putting crud in the old girl.
I'm lucky, second owner and first took really good care of her.
Sep 29, 2009
198
60
norwich
swift escape 640
since 2009
which one :Blush:
Many thanks :Smile:
you quote fiat in text. but your lovely eagle looks like a ford transit base .
be carefull when buying parts the 2 makes are very different
LucyCaitlynW
LucyCaitlynW
68
78
Kent
:Doh: oops, don't know where "fiat" came from ~ senior moment?
Your absolutely right Toluny is a Ford base :Smile:
Thanks for pointing out error :Blush:
scotjimland
2,327
10,087
A Woosh bang
I tried that.. just to check as I already know ..
for my Honda it suggested all of these.. :Doh:
0-30
0-40
10-40
10-60
15-40
15-50
20-50
5-20
5-30
5-40
5-50
so what use is that to a novice... ? :Doh:
best place to get the correct oil type and viscosity is from the car manufacturer which you can find it in the owners manual..
failing that auto shops have books that you can look up..
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
Most but not all vans have a sticker somewhere under the bonnet with the recommended oil even down to make
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Hi Lucy. Not sure where you are in wonderful Kent, but if there is a Ford dealer nearby, you could pop in and ask what they recommend. They will probably tell you to use their own oil ( motor craft) but once you know the correct viscosity, you can use any good make.
I found THIS, it might tell you what you need for all servicing info if you click the vehicle tab and enter your reg number.
Allan
Feb 16, 2013
19,734
52,021
uttoxeter
50 years
If it's the old banana tranny engine you can put pretty much anything in it, it will never go wrong:thumb::thumb:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
0-30
0-40
10-40
10-60
15-40
15-50
20-50
5-20
5-30
5-40
5-50
What's the registration?
LucyCaitlynW
LucyCaitlynW
68
78
Kent
0-30
0-40
10-40
10-60
15-40
15-50
20-50
5-20
5-30
5-40
5-50
Thanks for suggestion, there is no owners manual and having made enquiries about my Golden Eagle it seems that there never was one :RollEyes:
LucyCaitlynW
LucyCaitlynW
68
78
Kent
Tried that one first :Smile: no sticker (will put one in when I track down which oil). Thanks though
LucyCaitlynW
LucyCaitlynW
68
78
Kent
Allan
Thanks Allan. tried site but sadly didn't recognise number plate.
Can't get vin number at the mo.
Rainham and widow of Customs Officer
LucyCaitlynW
LucyCaitlynW
68
78
Kent
No idea what above is :Smile:
She's been well taken care off by previous owner and
I want to keep up the job :Smile:
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
Forget about it being a Golden Eagle - it is a Ford Transit.
I change the oil in mine (well, my man does) every 3000 miles, and with nearly 150000 miles on, it still hums along with no funny noises, never uses any between changes.
TheBig1
17,630
43,279
LucyCaitlynW
LucyCaitlynW
68
78
Kent
Thanks :Smile:
Only funny noise is when steering wheel in full lock :Smile:
Will check if I can find out when last oil change was and
then get oil for Ford Transit :thumb:
scotjimland
2,327
10,087
A Woosh bang
I don't put reg numbers on forums.. but it makes no difference, and why would it ?
The same 'selection' is suggested with the Make, Model and Year ..
frankly, I would never contemplate using some of the grades suggested..
The correct oil depends on ambient temperature.. hence the number of grades..
for example.. for operating ambient temperature of -30 to +40 c
my car uses 0w- 20 , or 0w-30 or 0w-40
other grades can be used in warmer climates .. for example 15w-40 ..
as as said earlier.. the very best place to get the correct grade for the operating temperatures for your vehicle is the manufacturer..
This is always in the drivers handbook of the base vehicle.. (not the van convertor) if that's lost.. any main dealer will advise.
Portland
923
1,424
Conwy
C class
20 years
Hi, Unless I've missed seeing this in the posts you have not said if its petrol or diesel? However in view of the age DO NOT put any fancy oil such as a synthetic oil the engine will not accept it and you could have disastrous results. Just put in a good quality known make oil. :thumb:
LucyCaitlynW
LucyCaitlynW
68
78
Kent
Diesel, I've ordered the handbook so hopefully I'll get it right now :Smile:
but thanks for the heads up re synthetic oil.
Lucy
Techno
Jul 28, 2010
15,475
20,756
May 2010
Usually the regular oil for normal use and service intervals comes up top of the list
