Which van to convert? High top medium wheel base! (1 Viewer)
Happycoach
Dont own one yet
Im a newbie
new to the land of camper vans but familiar with fitting out interior domestic designs. We are seriously looking to experience our own countryside and costal beauty, over extended trips, but which make would you guys suggest as the best host vehicle, looking at crafter, sprinter and master ( merc, vw, Renault/ Vauxhall’s) . Finances dictate host vehicle £5000-£10000, the budget to fit it out, would be above but not massive. Are there any positives and negative experiences you could share to help guide our hunt. thanks in advance
Jan 17, 2014
1,261
2,387
Wellington, Telford, Shropshire
Since 1977
Here is an interesting Blog for you to follow on the converting a New Crafter into a Motor Caravan https://vanwolf.blog/
I've been along the route of converting LWB VW Thansporters five times during the past 14yrs. We've loved them and been all over Europe in them. I'm willing to share any knowledge that may help anyone.
34127
Have a look at diymotorhome.co.uk which is a sister site to this one, may get some ideas from there.
MisterB
5,970
13,348
Adria 670 SLT
Have you considered a Nissan Elgrand import from Japan. A lot of them come with pop up roof already fitted?
11,941
9,134
Hi with your budget I would give the scabby mercs/ VWs a miss unless you are repainting:(Renault are decent size but still above 4 ins narrower than the Fiat stable vans ...as already been said you get a 6 ft 2 ins wide bed across (transversely) which opens up a lot more layouts.My vote goes to Fiat, Citroen or Pugeot
Feb 16, 2013
19,789
52,224
uttoxeter
ambulance conversion
50 years
Hi & welcome . As big as you can go would be my choise & a full clear head height when insulated.
there you go , i would suggest as small as you can get all you need in, far easier around towns, and narrow roads.
Nasher
2,094
7,179
Pontardawe
Pug Boxer
As others have posted, Merc sprinter & vw crafter (same van, different badge) will be hard to find rust free within your budget
Fiat Ducato, Peugeot Boxer, Citröen Relay are galvanised, wider & a much better shape for conversion.
Personally I went for the Boxer as it has a cam chain rather than the belt of the Ducato (Relay same as Boxer)
There is a choice sizes I decided on the mwb (L2 H2) at 5.5m but the most popular van model is the lwb (L3 H2) at just under 6m
Aug 18, 2014
23,886
134,770
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
I'm looking at similar at the moment & find that it isn't possible to stand up in an H2 ?
Aug 18, 2014
23,886
134,770
Lorca,Murcia,Spain
Transit PVC
I was looking at an H2 on a boxer here the other day & we had 1,75cm
My converted van has a ceiling height of 6' 3" (1.9m)
I'm guessing you're very tall?
No only 5'10" , 1,74m but semi high transits my head is touching roof. The boxer I was interested in had a height of 1,75m but was a full insulated van. I'd discounted anything except full height roofs since . & concentrated on ivecos as 99% of them here are full height H4's whereas most Transits,boxers,ducatos ,etc appear to be semis where my head is touching the roof.
Here having conducted a bit of research an
H1 = normal flat roof
H2 = normally comes wit seats & you are doubled over until seated.
H3 = passenger transport ambulance type whereby head is touching the inside of roof at 1,75ish but around 1,83 without any insulation but is not enough to work for me.
H4= 190cm+
Sep 17, 2017
5,534
10,352
Birmingham, UK
A-Class
Are you sure about those measurements? My Ducato is a L2H2 (5.4m) and I've got loads of headroom above my 1.7m height.
17,653
43,486
you get a lot of value for money with an iveco. as mentioned earlier merc/vw rust for fun and at your budget you will be buying trouble
not all fiat engine options have a belt. the 3ltr is the iveco engine with chain
RandallC
1,242
3,488
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Hi And Good Luck
As a thought and given other threads on the subject ….. Don't pick a van with a sliding door...
Apart from the "you can never close it quietly) how do you cope with all the heat in the chilly months disappearing out the huge side door in an instant.
3L fiat isn't the most fuel efficient (5,000kg tag at 22mpg) but does the job with ease, no struggle up hill or lack of overtaking power, never been left with the thought I/m rowing this (may be because its an auto so don't need to spend half my time with clutch & gear stick).
(think it time for an old forum smiley) Ahh yes, this one
:reel:
Misterg
221
213
N Wales
Self build PVC
H4= 190cm+
The 'H's aren't standardised between manufacturers (other than a bigger number = a higher roof) and vary completely between different van models.
Headroom (before conversion) in a Transit "H2" is 1.89m for FWD, or 1.79m for RWD. For a Ducato / Relay / Boxer it is 1.93m. A Sprinter H2 is over 2m (but narrow). You really need to check the details for each model.
There's 1.87m or 6ft 1 1/2" headroom in my H2 Relay after lining & insulation.
Pugsy
519
1,391
D&G
Van conversion
Just measured my l3h2 boxer
25mm insulation in floor and roof,6mm ply on roof and 12mm ply on floor plus vinyl and carpet .height is 1.88m ; 6f 2".
Hope its some help.
Cheers Cris.
Jan 30, 2017
26
13
swansea
self built PVC
since 2016
Boxer/Ducato/relay L3H2 are ideal and what the majority of most manufacturers use. As said by someone earlier they are the widest of all the panel vans inside so lots of layout options. I went with rear lounge layout which converts into 6’x6’4” bed. When I build my next van I will put fridge above wardrobe as you use the fridge a lot more the wardrobe and my knees are getting on a bit.
Aug 18, 2014
23,886
134,770
Lorca,Murcia,Spain
Transit PVC
I can only go by what I have seen here. The semi high transits with insulation my head is just touching. Full height insulated rear wdrive enough room.
I looked at another semi high which ticked every box until I got in the rear & by the time floor & roof are insulated/panelled my head would be touching the roof. Problem I have is that many I'm interested in are so far away that I have to rely on phone conversations for measurements.
My existing coach built I have 6'1" at the rear which is ok & 6'5" at the front part.
The older 2,8 is also an iveco engine fitted to citroens & peugeots..
** Hopefully this is all useful to the op:D
Aug 18, 2014
23,886
134,770
Lorca,Murcia,Spain
Transit PVC
To convince myself I wasn't going mad I've just been to look at a semi high transit. & my head hits the roof, not the roof bracing bars, but the actual roof. So at least I know with transits I have to have a full height
GPW
606
878
Cambridge UK
Globescout Plus
Slight to minor!
There's a softlock option now on the Fiat/Boxer/etc. base that seems to work, so you get it mostly closed and it gets grabbed and pulled shut - had it on my Hiace too. Developed by a sleepy Fiat engineer no doubt..
The heat loss is a good point but one can always leave by the drivers door (wind permitting - don't try it with a gale blowing from behind the van!). Maybe a case for a thick curtain to block the door when it's cold
