Which Tyres? (1 Viewer)
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
Hi All,
Could do with some help on this.. My 1994 Hymer 654 is to put it bluntly poo in the mud, I gather it will be the same in snow... with that in mind.... what tyres are favoured by you lovely peeps on here?
I have been looking at the michelin agilis alpins mainly because of both wet and economy ratings...
Am I better getting an "All Season" tyre like the new michelin cross climate (if i can find the size) or just run winter tyres all year?
I camp in fields a lot and would like not to just wheel spin when trying to get on and off lol... or at least have a little more traction...
Any help would be fabulous!
STu
WAG2CRU
376
495
Argyll
Hymer B654SL Star Edition
since2012
Our B654Sl is on Michelin Agilis camping which are M&S, so far, not had a problem in mud or snow, it is on 16" wheels.
Dec 12, 2010
5,412
21,565
Cumbria
since 2011
Plenty on here sing Hancook m&s tyre's praises, I fitted Toyo H09's which are a winter tyre that I run all year. I've only done 15k miles in three years and the fronts have worn a bit, but I'm expecting at least another 10k out of them and at £83 a tyre I'm happy with that. Not been stuck in any fields since we got them.
Dec 10, 2013
3,423
12,229
South Staffs
Pilote P740GJ
Since 2013
Once your tread has filled up with mud it doesn't matter what tyre you have on but someone will be along to say it does. :)
Poohbear
280
473
Worcester
Swift Lifestlye 644
June 2015
Have you considered some form of training? I generally find that when other people are slipping and sliding and wheel spinning all over the place, I manage to drive away with very little wheel spinning. I have manned grass car parks for charity events where you find that some people will give it loads of throttle and drop the clutch and then wonder why the wheels spin and the car digs itself into the ground. Other people just drive away with little or no wheel spin at all.
Jan 3, 2008
3,341
5,359
Pakefield, Lowestoft, Suffolk, UK
Looking
I think gently does it is the best way and the tyres tread design can do what it's designed for. I doubt M & S tyres would be designated that if they were not suitable or gave better performance than standard tyres.
ThePeltonian
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
fabulous.. thanks for the info
I'm not a heavy footer when it comes to mud where possible 2nd gear and low revs...
Just need some new tires that will give better grip in the mud - the hymer I have is FWD and not as much weight over the front as the back so slips n slides on the hankooks that are on (although they dont have much of a tread left)
ThePeltonian
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
Hi All again...
Ok I have found a couple of tyres that may be worth it..anyone comment? Also could anyone explain if going down to a 113 from a 116 on the front will make any difference?
Also has anyone run winter tyres all year? bearing in mind I dont use the van all year probably do about 5k at the most but some winter driving.
£107 delivered... still need to get them fitted and balanced
http://www.oponeo.co.uk/tyre-details/michelin-agilis-alpin-215-75-r16-113-r#95912153
116 versions £111 still need to get them fitted and balanced
http://www.oponeo.co.uk/tyre-details/michelin-agilis-alpin-215-75-r16-116-r#96376664_reviewslist
Then the michelin agilis camping (113) are £127 at dexel.co.uk fitted with balancing..
Would winter tyres be good all year? I rarely go over 60mph lol
Any help appreciated
Stu
Poohbear
280
473
Worcester
Swift Lifestlye 644
June 2015
There is no reason at all why you shouldn't use winter tyres all year round except cost, they are generally more expensive to buy and they don't last as long but if you can overlook this then it makes perfect sense.
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
Hi All again...
Stu
Don't know where in the UK you live but my son in law has a tyre fitting business near uttoxeter and would fit them very reasonably and has a shed large enough to get any vehicle in.(y):)
ThePeltonian
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
Sadly i'm in South Yorkshire :)
Hi thanks for that... They are £16 cheaper per tyre than the camper versions and i can get them fitted for £10 per tyre so would be £12 cheaper as only fitting 2x on the front....
Still got some time to work it out.. might just plump for the michelin camping ones.. M&S rated might be good all years..
Jul 29, 2013
9,071
18,526
Salisbury
Hymer B678DL A class
since 2011
Hi All again...
Stu
be careful if deciding on 113 as that is the max weight per tyre and you have 116 which take more you need to check axle weights to find out if they are suitable I can't remember the tyre codes but it is important.
Jul 29, 2013
9,071
18,526
Salisbury
since 2011
Tyre Load Rating Table
The following table shows what the weight that each index specification is able to carry:
Load Index Load in kg Load Index Load in kg Load Index Load in kg
62 265 84 500 106 950
63 272 85 515 107 975
64 280 86 530 108 1000
65 290 87 545 109 1030
66 300 88 560 110 1060
67 307 89 580 111 1090
68 315 90 600 112 1120
69 325 91 615 113 1150
70 335 92 630 114 1180
71 345 93 650 115 1215
72 355 94 670 116 1250
73 365 95 690 117 1285
74 375 96 710 118 1320
75 387 97 730 119 1360
76 400 98 750 120 1400
77 412 99 775 121 1450
78 425 100 800 122 1500
79 437 101 825 123 1550
80 450 102 850 124 1600
81 462 103 875 125 1650
82 475 104 900 126 1700
83 487 105 925
If you still have questions regarding your tyre size, do not hesitate in calling our team of tyre experts on Broken Link Removed.
ThePeltonian
ThePeltonian
105
27
UK
1994 Hymer 654
Since 2001
Hi all,
Ended up getting Vanco Campervan tyres with the 116 rating they seem pretty good so far, will run them a year and see how they fair
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
I fitted Hankook RA08s to the work Ducato (2.0 litre SWB) earlier this year to replace the Good Year Cargos that were on it. THE GYs were awful and would slip even on dry grass. Last Sunday we visited a local farm shop and had to use their "extended parking" which is a field that slopes gently up away from the road, got in with no problems but when we came to leave I had to reverse up the field to get out, I did suffer wheel spin but where the GYs would have just spun and got nowhere the Hankook's more open tread was able to self clean so they still found traction and I was able to get out under our own steam. Fitted some Good Year "Ultra Grip" to a customers van last week and they look the business with a really quite aggressive and open blocky tread pattern but I obviously can't give any feedback on off road or winter conditions performance.
D.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
if that was true why do motorsports that run on mud bother using them rallying autograss etc
It is true but ........... purpose-designed winter & M&S tyres have a more open and deeper tread which allows more tread flex to keep them clear. They also use a softer rubber compound for better wet grip.
TerryL
6,184
8,186
North East
Low Profile
Been running on Continental Vanco 2 winter tyres for several years now and only got stuck once when a site we were on flash-flooded (no rush, waited 24hrs and got off okay). Apart from that even sloping slippery grass has been no problem - and they saved me from a nasty a week or so ago on a damp motorway when an idiot cut close in in front of me and slammed his brakes on when he realised he had nowhere to go............. Thankyou Conti and ABS!
As for mileage, yes they do wear a bit quicker than ordinary tyres, but it's not significant and for most they will be replaced due to age rather than tread depth. I recall getting about 30000 miles out of a front pair, the second are just in need now of replacing, along with the rears at 60000. Actually the rears are only going to be replaced as they are over 5 yrs old.
Been browsing the net for prices and found I can get a full set at £90 each, including fitting so I'll stick with what I know.
