Which TV?
Discussion in 'Motorhome Chat' started by Barabus, May 3, 2011.
  1. Barabus
    Barabus Read Only Funster
    Apr 29, 2011
    10
    Peterborough
    I'm looking for a reasonably priced (Upto £250) about 22" and prefer LED backlit, any suggestions please. Are there any benefits over a dedicated MH/C/B TV ie. Avtek to the known brands ie. Toshiba etc?
    Si :Smile:
  2. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
    Hi you pays your money and makes your choice :thumb:Lots swear by Avitec etc, while other more cash wise save over 100 quid and buy other makes --see attachment
    terry
  3. callumwa
    callumwa Read Only Funster
    Jan 16, 2011
    4,113
    4,518
    Tyne & Wear, sometimes..
    Just make sure you get a TV which will run on 12V as well as 240V, and check the power consumption.
    We have an Avtex and a cheap 15 " from Makro in the van. Both run on 12V as well as 240V, both have built in Freeview, DVD players, USB input etc etc.
    The Avtex does have much better and wider range of viewing angles and picture quality.
    I suppose you do still get what you pay for. :thumb:
  4. freelanderuk
    freelanderuk Read Only Funster
    Sep 24, 2009
    1,022
    541
    Saltfleet/Lincolnshire
  5. canopus
    canopus Funster Life Member
    Nov 27, 2010
    3,224
    3,584
    Lincolnshire
    We are considering changing our current tv which is a 240V AC Toshiba. We also have a 12V Oyster sat dish and view through a 240V sky box.
    If we bought the Avtec (mains and 12V) with built in freeview would it work with the Oyster dish and could I then ditch the sky box. Or should I be looking for freesat tvs rathher than freeview?
    We currently have one 110Ah domestic battery running mostly LED lighting water pump, and displays.
    Any suggestions guys please?
  6. callumwa
    Jan 16, 2011
    4,113
    4,518
    The Avtec will work with the Oyster as should any TV. The Oyster dish is just your antenna.
    Freeview does not work via satellite. For that you will still need a sat receiver or a TV with built in Freesat (still quite expensive).
    Again they would still need a 12V power option, otherwise you will need an invertor for your existing Skybox. Alternatively get a 12V sat receiver which will get all the free UK channels and can also be used on 19E if you travel away from the "Sky Footprint" on 28E.
    :BigGrin:
  7. Barabus
    Apr 29, 2011
    10
    Peterborough
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
    :Eeek: 60w is a big drain from the battery :BigGrin::Wink:
    terry
  9. Barabus
    Apr 29, 2011
    10
    Peterborough
    Is that why people go for the small 15 or 16 inchers Terry?
  10. freelanderuk
    Sep 24, 2009
    1,022
    541
    i think the 60w is when its using the dvd player as well as when using just the telly it hardly registers on our battery display
  11. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    60w/5amps is when using the DVD player and i reckon is quite normal power consumption.
    i would expect the tv tuner to be around 2 to 3 amps (24>36w) at most.
  12. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,503
    2,609
    UK / Spain
    Hi, we got a LED TV its light and low powered and we are very pleased with it, ours came from Germany and I think it was about £150, shop around its a Odys Fino 15.6 inch 12v 240v LED backlit TV.
    Product Information
    With the very latest LED Backlight technology the Odys Fino 15" TV is a great buy. LED Backlights has a number of significant advantages; low power consumption, light-weight, thin, clear picture.
    Power usage - just 2 Amps on 12v (24 Watts). Weight - just 1.4Kg and size - the screen depth is only 40mm.
    Features: 15.6" Widescreen display, Digital (Freeview DVB-T) tuner with Electronic program guide, Analogue TV Tuner supporting All european countries including France (Secam L). 2 x 3W Speakers, VESA Wall mount compatible. Excellent connectibity: HDMI, Scart, S-Video, VGA, USB and A/V RCA Inputs. Headphone output. Remote control
    Overall a very nice budget set that is so light and thin compared to other leisure tv's.
    Shane sells them at Snellyvision.
    :Smile: Bob.
  13. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
    :notworthy: GETTING MIXED UP WITH WATTS AND AMPS:Doh: ours is 17 ins built in dvd and 35 w -- yep bigger tv = more power-- cheers John for pointing it out :thumb::Rofl1:
    terry
Similar Threads
  1. Ben9090
    12
    474
  2. Norfolk Red
    39
    1,219
  3. Timcropp
    288
  4. Madmag
    5
    375
  5. PORKSTER
    12
    825
