Which Sikaflex is Best? (2 Viewers)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Just about to buy a couple of tubes of Sikaflex, but it seems that there are two different grades, 22 something, and five something..........Is one better then the other, or dosent it really matter?? Going to use it to seal a new roof light in.
Ta.
GJH
29,450
38,827
None, now sold
2006 to 2022
When I was searching for an answer to a similar question recently the most recommended over various forums was Sikaflex EBT. I bought some for Ā£6 or so a tube from Screwfix.
It gave a very good result but takes a heck of a lot of squeezing on the mastic tube to get it out.
Oct 29, 2012
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
there are different grades for different jobs.Let google be your friend::bigsmile:
deanroofing
297
253
bedfordshire
since 2010
Silkaflex 512 is more like an adhesive, peeps stick their solar panels on with it so shows the adhension it as, the 221 is better for joints it still adheres well but should you want to rake it out anytime it would be easier. Good luck with it.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
WOW, I didnt know you could STICK a solar panel onto the roof. I was going to drill and tap mine, using Mini exhaust rubbers between the panel and the roof.
Dec 6, 2011
11,600
25,453
South Wales
Coach built Adria
they stick just about everything these days.... screws means holes.... holes means potential water ingress...:cry:
i just marked the roof with a crayon ( kids stuff ) easy to clean off if you get it wrong and easy to see, where the fixings had to go and then stuck em down.. simples:thumb:
froggy59
89
83
walkden
c class
since 2009
It gave a very good result but [HI]takes a heck of a lot of squeezing on the mastic tube to get it out.[/HI]
[HI]
[/HI]
I just left the tube of sikaflex on the radiator to warm up and it came out very easy:roflmto:
Alan
jb0371old
465
408
Autotrail
1 year
Sikaflex ebt from screwfix. Fitted a rear camera assembly to mine, sticks like the proverbial, with adhesive and sealant with elasticity, plus easy to get hold of in white and black
GJH
29,450
38,827
None, now sold
2006 to 2022
Sikaflex ebt from screwfix. Fitted a rear camera assembly to mine, sticks like the proverbial, with adhesive and sealant with elasticity, plus[HI] easy to get hold of in white and black[/HI]
And other colours. I bought grey, which was a nice match for the side skirts :thumb:
Sep 16, 2013
2,220
7,983
Horncastle, UK
An alternative is Stixall which is available from Toolstation.
I've used it for loads on my van build (it was recommended to me on a self-build forum by a lot of people) including fitting room lights and sticking down solar panels.
11,932
9,097
Send an email to technical@uk.sika.com tell them the materials you wish to bond and they will reply with the recommended product.
Gordon
This is the way to go :thumb:Sikaflex is well known for letting go of some plastics after about 3 to 4 yrs --also try calling Soudal :thumb: about half price of Sikaflex :winky:
I tend to use PU40 from toolstation for most jobs now just because it's easy to get :thumb:
terry
daisy mae
675
597
Leicestershire
C class Coachbuilt
I`m a newbie, now 1 year
I used 221 on my first mh as it was very hard to get out of the tube I put very hot water in a small bucket and stood the tube in it upright, flowed out very well kept putting it back in water until job finished. brilliant stuff, although can be messy.beware once it is stuck it is stuck, you do have about an hour to get it in the right place.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Thanks everypeeps, just ordered the EBT from Fleabay. :thumb:
Sep 23, 2013
2,586
8,834
Lincs
Globecar Campscout
Silkaflex 512 is more like an adhesive, peeps stick their solar panels on with it so shows the adhension it has
Is this just the flexible panels, where the whole surface is stuck down, or will it also hold the rigid panels that are designed to sit on raised feet with an air gap between roof & panel (& where the surface area of the feet in contact with the roof is very small)?
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Wondering the same myself. Dont want my panel ending up as someone's new greenhouse panel next to the M6.........:Sad:
Oct 7, 2011
351
388
hereford
Hymer A class
since 1980
I'm just about to use some sikaflex 522 on the roof of my van.
Is using a finger dipped in white spirit the best way of smoothing it out ?
Sporknoggin
Murvi Meteor
I find I get more consistant results with the back of a teaspoon, instead of my finger.
