Steve
I have a bosch tassimo it pulls 1300w or 5.5amps @ 230v at 12v the ampage is 100amps. But it is only on for a minite so not a lot out really and i do have 480amp of batteries.
Thanks Robert.If you're getting low voltage bleeps from the inverter control panel then I'd be careful
The Carthago control panel seems to alarm at a higher voltage, so I tend to ignore that
Thanks MartinHi Richard we used to run ours on two 80ah without beeping so again I would ask how thick and how long are your 12v supply cables,
Should be indeedThanks Martin
The battery locker is one side of the hab door and the inverter is the other side so about 4ft cable run plus a bit for bends and connections.
The cables are hefty and it was all fitted by that well known emporium near Taunton so should all be adequate.
Richard.
Dot nil nada zilch ? Lol
Dunno Robert, the ones I have are cheapo Alcafe (Aldi) bought as a trial taster.Does it take Nespresso metal pods?
What sort are your two 125ah batteries?
Mrs C forgot to pack the capsules for our Nespresso machine and tbe compatible ones they sell in France taste like mud
@Mr Mousy if they were 16mm dia I would say yes "they will do the job", but if they are 16mm2 cross sectional area I would say "don't bother". We have 50mm2 (like welder cable).Just bought (well free from an electrical wholesaler whom I know) some 16mm super conductive trii something or other cables to replace the existing ones. Fingers crossed it solves the bleeping problem.
Yes - if you are going for a moka pot then the Bialetti stainless steel models are the best. We have 2. It makes perfect espresso which you can then dilute to get the style of coffee you are after. With the right espresso grounds it tastes as good as any coffee shop coffee, it just takes a little practice.We have this Amazon product ASIN B0009Q1DSS . It works well on induction hob & gas. These are available in lots of sizes - we have the 10 cup one for home use - cup equates to expresso size. Not quite as easy as a machine but close
