- May 29, 2013
- 2,619
- 19,411
- Chausson best of Flash 10
- Several years now
In my MH I installed a voltmeter directly across the terminals of the Hab batteries and one across the Cab battery. Therefore I am able to see the voltage on them at any time. Both batteries are lead acid, flooded, sealed.
When the engine is running they both receive 14.2 volts.
When the MH is on hook up (pre solar panel) they both got about 13.2 volts.
When I first connected the MPPT charger, a Photonic Universe type, it showed that it was giving out 15v to the battery !
The PU instruction manual said it should be giving out 14.4v at boost charge and 14.2v at float charge. Talking to their tech help they advised me to change the battery type to GEL. I did and I got the right values.
However, I was able to go into USER mode and configure the outputs downwards as I still thought they were a bit high. I changed the outputs to 14.2 for boost and 13.8 for float. Much happier now.
Then I came across the video below, from Victron. In it at 5min in the Victron man says that float voltage for lead acid batteries should be between 13.1v and 13.3v.
So which is correct ? PU at 14.2v or Victron at 13.3v for float charging?
