What value fuse in solar cable ? (1 Viewer)
Nov 8, 2015
181
400
Rakitnika, Varna, Bulgaria
Damon Daybreak RV
Now in fifth year and with American RV
I am sure I have seen this info somewhere but cannot bring it up on search. I have just installed 120w panel wired through mppt controller to 100amp leisure battery and I understand that I should have inline fuse on positive side between controller and battery but can someone advise what value fuse this should be please, thanks
Mike4727
Nov 8, 2015
181
400
Damon Daybreak RV
Thanks Andy, is that the only fuse I need to put in - or would you normally put fuse between panel and controller - I noticed a label with "lightening "type symbol on the positive cable from the panel.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The instructions do not call for a fuse on the panel side BUT I fit one simply to isolate the panel if required. If you do choose to fit one just make it a big one
Mike4727
Nov 8, 2015
181
400
Damon Daybreak RV
Ah, that's ok then - if I need to isolate the panel I can just disconnect at the panel tails I guess. Thanks for the help Andy, another job off the list :)
43,330
49,446
That depends on the fuse holder used
A regular auto only goes to 30amp
I have a 50 amp bus fuse which comes on 6mm cable so only needed one through crimp and straight into the regulator
Never really considered a fuse in the input line.
Maybe i should know, but i dont.... how can you put a 12v fuse of any amp value in an unregulated 17v to 21v panel to controller line without it overloading ?
DBK
18,025
48,095
Plympton, Devon
PVC, Murvi Morocco
I've never heard of voltage rated fuses - other than some, which are the sort we are talking about, are designed for low, non-lethal voltages, but they are not voltage specific.
Techno
Jul 28, 2010
15,475
20,756
May 2010
A fuse is only a conductor and in this instance not used for over current protection but for isolation
Techno
Jul 28, 2010
15,475
20,756
May 2010
I use this
Broken Link Removed
Can just be seen at the side of my selector switch
