Solar Panel Isolation
Discussion in 'Solar Power' started by JeanLuc, Feb 20, 2016.
  1. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,815
    1,882
    Warwickshire
    I have a 130 watt panel feeding into a Schaudt LR1218 regulator. I fitted an additional 30 amp fuse in the +ve line between panel and regulator, purely for the purposes of isolating the panel: e.g. if I want to switch off the panel to prevent a false 14.3v reading at the battery when using the mains charger (EBL99) or when working on the batteries.
    It is a bit of a 'faff' fishing the fuse from under the driver's seat so I am thinking of replacing it with a battery isolator (or 'kill switch'). Any comments on this from the experts - does it sound like a good idea?
    • Like Like x 1
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
    I've been doing it for years (y)
    EDIT not the switch part but yes it seems a good idea
    • Thanks Thanks x 1
  3. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,702
    11,858
    Plympton, Devon
    A fuse does offer a small amount of resistance so I guess a switch might be easier to use and better electrically - but only if you don't have to make the wires much longer to put the switch in a convenient place.
    • Thanks Thanks x 1
  4. Techno
    Jul 28, 2010
    14,107
    14,921
    I never isolate the panel when it's putting out big amps though but no problem on float
    • Informative Informative x 1
  5. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,815
    1,882
    Warwickshire
    Fairly easy to do. I plan to mount the switch at the front of the driver's seat base but inside the well. This way I can arrange it so the switch handle is facing up and accessible from 'between my legs' so to speak! I shall just need to replace the present cable link from the existing fuse holder and link the regulator to the switch with a new piece. Not much longer - perhaps 10 cm.
    • Like Like x 1
  6. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,815
    1,882
    Warwickshire
    It's mostly for this time of year when the panel is not doing much charging but it still keeps the battery voltage at 14.3v, thereby limiting any charge from the EBL. When I am harvesting serious power, I would not want to isolate the panel other than perhaps to change habitation batteries - but that is an infrequent occurrence.
  7. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,027
    1,168
    Dronfield - Derbyshire
    • Useful Useful x 1
  8. laird of Dunstan
    laird of Dunstan Funster Life Member
    Feb 15, 2015
    1,202
    3,219
    lincolnshire
    id check that it has the EU or UK safety marks on that before i fitted it
