What size fuse for inverter (6 Viewers)
Feb 16, 2013
19,742
52,066
uttoxeter
ambulance conversion
50 years
I have now fixed a 500w inverter in the van , just for light duties and a slow cooker, most it will be probably 200w, , I have put a normal spade fuse inline on the positive line next to the battery, and put a 20 amp in it that didn't blow so now I have a 15 amp in it and it seems to be working fine, now I have seen things on the net that says you need anything up to a 100 amp , why? If my 15 amp isnt blowing with the cooker plugged in , is that ok.
2,356
10,237
what size is the cable.. ?
that is what determines the fuse or CB size.. it is sized to protect the cable..
If you don't know the cable size , was it supplied with the invertor ?
If so I wouldn't worry.. at full load the invertor would draw 40 A ..
so you will be safe using the 15A fuse.. that is equal to a load of 180 watt
The 200watt cooker will draw 16.7 amps so it may eventually blow the 15A fuse.. in which case use the 20A Fuse
53,496
150,317
You never know what you are going to plug into it in the future so providing your cable is suitably rarted I would fit a 50 amp fuse, I have a 100 amp fuse in line with my 1000 watt inverter.
chaser
Feb 16, 2013
19,742
52,066
uttoxeter
50 years
Thanks for that , I am useing 6mm cable , wasn't thinking of melting the cable , more if the inverter crashed or the cable got cut or some other calamity, it came with cable for a fag lighter but I am useing maybe three times that, so I was right first time then,
Makes a change(y):)
chaser
Feb 16, 2013
19,742
52,066
uttoxeter
50 years
I would rather have one that will blow quick, that's why I went for as little as possible (y):)
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
A 100 amp fuse is way over the top.
That will take some load to blow.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Not making any comment about the good advice you have been given regarding fuses, but I think I might be concerned about a 500w inverter that was supplied with a 'fag lighter' plug. Most such sockets are rated at 10 or 12 amps and your inverter can draw over 40 amps. Not great!
chaser
Feb 16, 2013
19,742
52,066
uttoxeter
50 years
I know that that's why I havnt used them(y)
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
These should not be sold with a power point plug.
If advertised as max output they can NOT get it from a cig, power point
chaser
Feb 16, 2013
19,742
52,066
uttoxeter
50 years
Can't argue mate, but put , inverters, in ebay, everything up to 3000w come with cig plugs, why?
Roadroamer
21
24
llanelli
elddis 115 coach built
since 1994
I am thinking of fittting a 3500w 7000w pure sine wave inverter and I am baffled as to what size fuse/circuit breaker help please
53,496
150,317
7000 w will be the peak power and the inverter will probably trip well before that.
So I would say 350 amp would be OK.
For an inverter of that size I take in you have a minimum of 750a/h of batteries and a means of recharging them like 750 - 1000 watts of solar.
23,836
72,558
A 6mm bolt should be about right !!! LOL !!!
And before anyone gets all twitchy it is a joke and not to be taken seriously !!!
Roadroamer
21
24
llanelli
since 1994
the reason for fitting a large inverter is I had a 2500w 5000w inverter which went bang using a 1500w coffee maker and the supplier said it is not man enough for it so rejected my warranty claim
53,496
150,317
Should have got tough with them, should have been fine. Carthago and Hymer only fit an 1800 watt inverter for a 1400w coffee maker.
2000 w will be more than enough. Just buy a quality one.
I have a cheap pure sine 1000w runs an 800W kettle & 1000w iron OK.
chaser
Feb 16, 2013
19,742
52,066
uttoxeter
50 years
would like to add to this , mine has never blown a 15 a fuse so why you would put a 200 a has always baffeled me , you would think it would have to be on fire before it blew one of them.
Roadroamer
21
24
llanelli
since 1994
is your 15a fuse in the thick cable between the battery and inverter?
53,496
150,317
If you have a 1000w inverter and use a 1000watts on the output it will draw around 90 - 95 amps on 12v.
Likewise a 2000w inverter will draw 180 - 190 amps when loaded to 2000w.
Sep 1, 2018
1,986
6,652
Strathaven
Pilote G741
Since 2018
I phoned the importer of my inverter to check fuse size , they told for my 1500w unit it was a 150amp fuse
so I’m assuming 500w would be 50amp but lennys sizes sounds good to me
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
I have our 3000w pure sign wave inverter, using 25sq mm cable, fused at 120A, kept going, not in this country, by 400w of solar. The only time it does any real work is the 900w kettle or toaster, on for just a few minutes, the rest of the time it’s charger, tv and stuff like that. :gum:
Aug 5, 2018
1,567
3,513
a
works for my 250 amp welder in the garage, not blown a bolt yet. Could only just about get the lid of the plug back on though :D
Aug 5, 2018
1,567
3,513
a
We used to have to do that with 13A plug tops when that was the only thing available to plug the welders in:giggler::giggler::giggler::giggler:
Oh Snap :D Works a treat (Couldn't be arsed to fit a 16 amp blue plug and rewire a socket for it :D)
53,496
150,317
Never going to work at 3000 watts with that size fuse.
