What should I put in this hole...
Discussion in 'Tech/Mech General' started by Sidney, Apr 29, 2013.
  1. Sidney
    Sidney Funster
    Jan 27, 2013
    1,176
    746
    Stamford
    Hi,
    I'm getting lazy as I get older. My new van has a massive payload and an obvious spot between the chassis rails for an additional tank.
    So I could put in:
    a, An extra fresh water tank (I currently have a 90 litre tank that is also used to flush the thunderbox)
    or
    b, A LPG tank at the maximum size permissible on the Channel Tunnel (details of what is permissible are given below)
    I suspect the water tank (with pipes and stuff) would cost circa £150 as a self install [HI]but what's the cost of getting a LPG tank installed?[/HI]
    Fixed gas container
    • If your vehicle is fitted with a "fixed" gas container the quantity of gas is limited to 47kg (or approximately 93 litres) for a single container and the maximum filling rate is 80% (or approximately 73 litres). In the case of several fixed containers the quantity of gas is limited to 50kg (or approximately 99 litres) on the whole with a maximum filling rate of 80% per container (or approximately 79 litres).
    • This filling rate will be checked via the gauge. If no gauge is present, the vehicle will be refused.
  2. ukbill
    ukbill Funster
    Nov 3, 2011
    4,908
    4,870
    benidorm
    just stash ya cash there worth more there than in a bank :Rofl1:
  3. SPUD'N'T
    SPUD'N'T Funster
    Aug 25, 2008
    2,731
    6,331
    YORK ENGLAND
    has your van got a spare wheel ? .... i wish i had room under the van for one
  4. Sidney
    Sidney Funster
    Jan 27, 2013
    1,176
    746
    Stamford
    Yes it's on a frame underneath at the rear - reminds me I must put a padlock on this. :thumb:
  5. TheDogMan
    TheDogMan Funster
    Mar 29, 2011
    658
    366
    Rugby UK
    The underslung tank is great and got myself an extra locker !! but it may cost a bit more than an additional water tank
  6. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,551
    7,608
    Tropical Bar,Benidorm.
    We made enquiries about having an underslung gas tank fitted to our van whilst at the Peterborough Show. The cost was in excess of £700 supplied and fitted.
    Brisey.
  7. Spenders
    Spenders
    Jan 19, 2013
    398
    362
    Tadcaster
    You could consider a BeenyBox.
    As I understand it it's an additional storage box (more like an exterior drawer) built onto the chassis that then slides out from the exterior of the vehicle... good for carrying stuff lower down so assisting with centre of gravity and freeing up space elsewhere. They have been discussed on other threads I think.
    Think they cost about £400 but that varies on size as they are made individually to fit the space on your vehicle.
    Simon :thumb:
    • Like Like x 1
  8. Sidney
    Sidney Funster
    Jan 27, 2013
    1,176
    746
    Stamford
    Yes I've seen these. They look very smart but TBH I'm not sure if I really need one. I think I'd only put some ramps in there which may be a little over the top.
