what leisure battery ? 2 x 110ah or 1 x 220ah ? via solar panel (1 Viewer)
brianrfc
5
falkirk
c class
newbie
hi there guys im having a little problem with my leisure batteries there only a year old and knackered so time for new ones my thoughts were on 2 x 110 ah batteries but when i started looking i noticed 1 x 220 ah battery this sounds strange but does 2 x 110 batteries charge quicker or same time as 1 x 220 ah battery via solar panel also whats better idea to go for 2 x 110ah or 1 x 220 ah ? i dont really know much about the way they charge i was thinking 1 x 220ah but got told that it might take longer to charge .......i would of thought 2 seperate batteries would take longer im so confused please help
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Both the same number of amp/hours so same amount of time to charge, 2 batteries would be easier to handle that's my thoughts.
Feb 24, 2013
13,089
101,499
Bolsover, Derbyshire
Hymer S800
not long enough
I have not heard of a battery that big but that doesn't mean too much
two points from me
1, if you can get them that big you might need to modify the mounting as it will be physically much bigger than your 110A
2, from experience we effectively lost the use of both batteries when one failed, so one might be a better option
As for charging benefits, over to the rest of you :thumb:
B
brianrfc
5
falkirk
c class
newbie
alpha batteries online very cheap plus free delivery my dad bought 2 x 125ah xplorer
and hes been in spain with the motorhome for a year and never had any probs living full time in motorhome watching tv for average 6 hours a day
bobandjanie
8,165
15,812
Javea, Spain
Pilote V600g
The first thing is how much room have I got ?
Can I lift a big battery into the space ?
And if I have 2 or more batteries and one is duff, and I take it out of line, :winky: have I still got power. :Smile:
We have 3 x 85ah batteries = 255ah and it works for us. :thumb: Bob.
Lord Mac
190
232
Devon
Autotrail
I'm a newbie
Newbie question...if you have a solar panel fitted is there really any need for large capacity storage batteries?
UK Pete
284
333
kent
Renault van conversion
on/off since 1991in campervanss
Iwould say 2x 120a batteries is the way to go, due to weight and storage, but first i would investigate why you only got 1 year out of the ones you have it could be they have been damaged by over charging or over draining,
pete
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Don't replace the batteries until you've worked out what fried the originals. If you killed a battery in a year, there is something wrong either with your electrical system, or the manner in which the batteries are used. Non traction lead acids do not like deep discharge, whatever the marketing sh*te on the side says.
However, once battery usage is sorted, there is no difference between 2 x 110Ah or 1 x 220Ah, provided you're strong enough to lift the 220Ah and have room to stick it. Either setup would have ridiculously high CCA and would live or die together. Personally, given identical quality, I would go on price between them.
I've got a 180Ah, and room for another, if I move the engine battery back to the engine compartment where it belongs...
