What is this for ? (4 Viewers)
Jun 30, 2010
7,925
27,237
1992 VW Auto sleeper Mono
Since 2005 this time
It looks like its for your Air bag Suspension
Apr 28, 2013
3,682
80,905
Alentejo,Portugal
Hymer A Class
Since the '80,s
I would suspect Dawn that the van is fitted with air assisted suspension,just stick the air line on it until you get it right for a smooth ride :thumb:
Oct 1, 2013
7,513
19,955
Lanzarote
Nil by mouth
Lots
It's for blowing up party balloons. Wish we had one.
43,337
49,540
Eh! No she didn't (I did of course), what should SHE see underneath then :Smile:
Something like this.....
DONT run the van is the bags have no, or very little, pressure in them....they can be damaged.
Mine run at 60psi holding up the arse end of 7500kg
Dont know wghat pressure yours would be but i would start around 40psi and see what the ride quality is like....a bit hard, reduce pressure....a bit spongy....increase pressure.
Other folks will give a more accurate pressure range
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Hi, I think you will find it's for your spare wheel, if you don't have A/S
Cheers, Dave:thumb:
Moodybrook
802
651
Wet and cold place outside of M25
4 wheels and a pointy end
still in nappies
Och no, it's an external Bagpipe connector, You have a Scottish van !
It is like for those gas barbecues but instead it is for making sweet music :roflmto:
Chudders
69
24
Newquay, Cornwall
I had an Autotrail and its almost certainly for the spare wheel underneath. If you look underneath there will be along tube connecting this point to the valve on a spare wheel so you don,t have to get at the wheel to check the pressure.
17,635
43,372
that reminds me I must fit my airline extension onto my spare on this van and cabletie the end to the towbar. much easier to top up the spare using that than crawling under every time
http://www.spairline.co.uk/
May 29, 2013
2,603
19,282
Tyneside
Chausson best of Flash 10
Several years now
If you find that it is for topping up air suspension, then by using this useful tip you could also gain some extra weight capacity. It might work with the spare wheel, not sure.
Top it up with Helium !! The amount of Helium which would be required to top up the air suspension should give something like 80kg of "upward lift".
Easily proved. Go to a weighbridge, weigh the MH, then ask one of the guys at the weighbridge if they have any "industrial grade" Helium handy (don't ask for scientific grade as that is way too expensive). Explain what you intend to do and they should be only too pleased to offer advice and help, that's when being a woman comes in handy, esp. if your blonde, us guys would have to offer the price of a couple of pints.
As an added bonus, any squeaks which had been due to the suspension are now at a much higher pitch and therefore inaudible !!
17,635
43,372
:ROFLMAO::ROFLMAO::ROFLMAO:
much like filling ordinary tyres with pure nitrogen (only super hot motorsports tyres benefit slightly)
i watched an episode of mythbusters some time ago where they had a lorry load of birds. does the lorry get lighter if all the birds take flight inside the van and effect the handling. result was a barely readable difference
why not fill the tyres with lpg? great as backup to gaslow and spectacular if you get a blowout:ROFLMAO::ROFLMAO::ROFLMAO:
Fireman Sam
1,421
2,513
Bushey
Class C
Only since 2012, but I towed for many years
I’m accustomed to a smooth ride.
Why deny the obvious?
Oct 1, 2013
7,513
19,955
Lanzarote
Nil by mouth
Lots
Some people don't even have spare wheels on their MH never mind one with it's own life support system
I'm so proper northern 'ard, Ive no wheels on my van.
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
See what you mean, now, but still not as posh as air-suspension!!!!!!
Cheers, Dave:thumb:
17,635
43,372
what happened?? some chav on a motorbike knick them and leave the van on bricks? theyre probably fitted to some scabby vauxhal corsa by now. at least they look better on that than on yours:ROFLMAO::ROFLMAO::ROFLMAO:
