What is this device next to my inverter (2 Viewers)
yorkist
64
31
Altea-Benidorm
busy researching now
sadly none yet
Hiya Funsters, can someone please tell me what this device is? It's located next to our Inverter. In our lounge there is a remote on/off switch for the inverter. Why would you need to use that? I though the inverter did its job and inverted as required by a particular device/socket. Am I wrong, again?
Les
Apr 18, 2008
301
4,201
Seaford
Low Profile
If you leave your inverter on while not in use it still uses some power don't know how much
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Looks like an accumulator to me......The air in it keeps the system water pressurised, (from the pump to the taps/outlets), so the pump dosent keep pressurising the system.
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
It's a Dingle Dangler for holding the left over power from the inverter when the solar is not feeding the air supply to the batteries. Very rare item. o_O
32,667
66,605
It looks like it's to do with the water system something like Tootsy suggests.
2,337
10,147
Enough of this frivolity...
As has been said.... Its a surge damper which helps to provide a smooth water flow by reducing pulsation and system noise, inside there is a pressurised rubber bladder.
Essentially it adds volume to the system and helps smooth out the pressure pulses from the pump..
this is the Whale model ..
9
9526
Aye, it's a surge damper and something I'm going to fit to our van when I get back home as my cold taps make the pump jump and bang like a randy kangaroo.
32,667
66,605
Prey tell what your experience is of this! :eek:
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
We have one fitted to our van, it stops the pump running on and / or chattering when you turn the taps off.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
MEDAL MEDAL............
