Water tastes horrible (2 Viewers)
A
AnnTone
the water in our motorhome tastes horrible, even when boiled for tea. :cry: is this normal? Can we do anything about it?
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
We had this problem when we first got the m/home. We used to use a (new) garden hose to fill with as many do but changed this to a food grade hose. Also we put some purifying tablets in the tank for a day flushed out and re filled with the food grade hose...problem solved. ::bigsmile:
A
AnnTone
Ahh I had not thought that it might be the hose we use giving it the bad taste, I will do some experiments, Where do you get foog grade hose?
artona
1,511
817
self build
40 yrs and still not got a release date
Hi Anne
we did the same as Ken, but in the end we fitted a nature pure water filter - a bit expensive but we will never have a motorhome without one again
stew
Tony Hunt
214
Wimborne, Dorset
RV A class
As well as the food grade hose treat yourself to a Nature pure water filter. These can be fitted in your m/home quite easily to just filter the water you drink. Its a case of just directing the water to another tap that you can position near your other kitchen taps. The rest of your water for showering, washing up etc will stay unfiltered. The nature pure is probably the best you can buy (not cheap) and gives you bottled water quality out of a tap. Its far more efficient at filtering the bugs etc than a normal kitchen water filter.
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Almost any camping shop sold by the metre. We bought a very long one which we cut to make a short and a long hose they join together via snap on connectors and have proved very worth while. Not cheap but in the great scheme of things well worth it. ::bigsmile:
H
Huckleberry
Hi Anne,
Had the same problem in my van and after getting tired of keeping separate water containers bought a Nature Pure filter. It has worked very well for me and was the first extra that I put into my new van.
The only downside for me was lack of workspace for an extra tap, so I installed it in the kitchen cold water feed, it did slow the system down. However because my system did not have the extra tap it was easy to remove from my old van and I have now put it on the cold feed in the bathroom of my new van.
Rodger
Tony Hunt
214
Wimborne, Dorset
RV A class
Cheap garden hoses are notorious for making water taste. clean the tank out with some purifying tabs and lots of clean water then buy the best hose you can afford, lay flat ones are best as they take up less room. I carry two of different lengths so that I can either join them together or use a different length singly, depends where your parked on site. I never use camp site hoses because you dont know whos used them or for what.
John S
10
We have had caravans and MH's for years and never use the water for drinking as the tanks stagnate and I used to get upset stomachs. We use a filter kettle and filter jug and just fill them up from the nearest tap. No more upsets and good tasting water. A lot cheaper than a filter tap. If we are going where there is not tap we fill up a water container.
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
:Cool: We have always filled our tanks with ANY old bits of tubing. Having said that. We NEVER drink water from the tank. Always from bottles. :winky:
Enodreven
xMember
Nov 28, 2007
154
Hi,
What does it taste like is a TCP type taste ?? as we had a kettle that made the water taste like if it had TCP in it , replaced the kettle and it went ? albeit it tasted like TCP even using bottled water
We are the same we never drink the water from the tank we always use bottled water ??
Tony Hunt
214
Wimborne, Dorset
RV A class
John. Put your hand in yer pocket and fit a Nature pure and you need never worry about what pond water your drinking ever again, the water that comes out is superb as others will confirm.
camcondor
1,034
480
East Midlands
We only ever drink bottled water, whether out in the van or at home. If we run out, we have a Brita filter jug in the van and at home to use in emergencies.
We never, ever drink water directly from taps or from the motohome tank. Had too many dicky stomach episodes to go down that route again. Never fill up with hoses from the campsites, however convenient - have seen them used to flush toilet cassettes and being pushed right into a cassette (yuk):Eeek:
Must get around to fitting a filter on the m/h although it isn't critical as we only use bottled water if we can.
camcondor
1,034
480
East Midlands
We don't have problems, Tony - I was just sharing what we do re drinking water. We are quite happy with using bottled water and see no need to change at this stage. It's just a different way of ensuring the drinking water is more satisfactory. And, no, we don't use Brita filters primarily - I'm sure lots of others are better, we just happen to have some perfectly functional Brita stuff which comes in handy as an emergency. Different strokes....:RollEyes:
2escapees
Why buy bottled water... all that plastic, expense and trouble fit a Nature Pure filter.
Try this link
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
:ROFLMAO: Our Newmar came with one already fitted. Another was fitted to the Ice Maker. Not my scene. Can't be bothered buying/changing filters every 5 minutes. It's quicker, easier and healthier using bottles. Think of the exercise we get carrying the bottles. In our Wild Camping days. We used to fetch ALL our water by Mountain bikes using 2x5Ltr bottles in each knapsack on our backs. We even used to fill the tanks that way. :winky:
