Water run lines (1 Viewer)
mudmover
53
Wales
Low profile
I'm sure this has been asked a million times already but can anyone advise how to remove the black marks that are formed from water running off MH when its not in use.....I tried with wax but to no avail.
Got to keep my sparkling nearly 12month old dethleffs sparkling::bigsmile:
cheers
MM
M
mudmover
53
Wales
Low profile
T Cut
T-cut does it for me, and any other stubborn marks i come across:thumb:
Tim
Dosen't Tcut gradually thin the paint layer? Its ok once in a blue moon BUT I'm looking for somthing to use say every 3months.....The MH is you yet ready to be decorated with smiling faces and rainbows ect :ROFLMAO:
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
i use autoglym motorcycle cleaner put on with a small rag,(it wont harm the paintwork),just before i wash it:thumb:
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Buy a bottle of "Star Drops" the plain type in a bottle that you dilute, and use an old plastic spray..
Not the Kitchen Star Drops Spray... That contains "Bleach"...:Sad:
Spray diluted onto offending area and the black marks will wipe off easy.. :thumb:
43,334
49,531
most motorhomes dont have paint as such.....its a gel coat applied in the laying up process of the fiberglass panel and is more robust than regular paint.
a good wipedown and regular waxing, especially round the window openings, after rain is usually enough to keep black streaks at bay.
the crap seems to leach out of the flexible sealant and rubber window seals.
MikeandCarolyn
2,170
1,468
Worle,North Somerset
G101 has been mentioned in previous threads I believe-I have obtained a small bottle but am a bit dubious about it.
When a substance is labelled 'Non-Caustic' and then I see it contains Sodium Hydroxide ::bigsmile: It makes me wonder :ROFLMAO:
Any users care to advise on dilution rates for paintwork ?
Mike.
dennismartin
135
19
hull
c class
im a newbie
hi
i use to own a large body shop we would use farecla g10 then a wax as a bodyshop we didnt use silicone wax but it does give a better shine you can also use g 10 on plastic windows works real well
cheers
MM
Try typing streaks into the search engine above.
