Water pump (2 Viewers)
RogeTeri
367
165
Abrantes, Portugal
February 2013.
After my battle to sort the toilet out I hoped for a peaceful few days, but no! Just filled the water tank. Switched the pump on. Can hear it working. But just a splutter from the taps. Might be an airlock but not sure how to get the water flowing! Any suggestions will be greatly appreciated!!
ukbill
5,501
5,274
Pinoso
4 berth low profile
normally just let it run it should clear
RogeTeri
RogeTeri
367
165
Abrantes, Portugal
February 2013.
Have tried that Ukbill can still hear pump but no water!
ukbill
5,501
5,274
Pinoso
4 berth low profile
at times i have let mine run for ages to clear is it both hot and cold ya not getting
RogeTeri
RogeTeri
367
165
Abrantes, Portugal
February 2013.
That's right. Turned kitchen and bathroom taps on. They are both h& c mixer. At first their was an air gushing sound with spurting water but now nothing at all. The pump is still running
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
We usually just keep turning the taps on and off, eventually the spurts turn into a steady stream, just be patient, it WILL happen.
Cheers, Dave(y)
11,932
9,092
Hit it with a hammer -if that does not work hit it with a bigger hammer and buy a new pump (y) Try the first suggestion -honestly it may be air locked at the pump ;) also check pipes for tightness if all fails go to second hammer
terry
pegleg
71
26
cheshire
Low profile
12 years
I open all the taps to hot as the air in the boiler has to go out as it fills up with the water then you get the spluttering then the water ,then turn the taps from hot to cold till you get a flow of water on all tap including the shower ,best do the most away from the boiler ,forgot to say the boiler has a anti freeze plug switch on mine which has pulled up so the water stays in boiler ,and there is a little open valve going to the taps, which when you are emptying the water from your drinking water tank you open it and you push the freeze button down and open all taps open with the water pump switch off so it can drain all the water away for winter etc hope this is any good for you (y)
11,842
14,071
I'm assuming your water heater is full, as no water will flow till it's full which may take a while (might be 5-10 minutes). If it is full then you can try sucking it to help the pump to prime. Turn off all the taps except the shower, take off the shower head and have a good suck on the hose. This often works (and gives you a facefull of water.)
Edit,: also make sure the water heater drain tap has not opened, though if it has you will get water flowing, just out the bottom of the van.
23,836
72,510
Just a thought..
The dump valve for the boiler is not open perchance ?
RogeTeri
RogeTeri
367
165
Abrantes, Portugal
February 2013.
Problem solved!!! Thanks for all the helpful tips! I finally crawled into the garage with my mallet determined to hit something! After exploring round the boiler and pipe work I discovered a loose electrical connection on the ware pump. A little twiddle and suddenly flowing hot and cold water. What a relief.
Now all I have to worry about is my operation next week to treat prostrate cancer. Life's a bitch but at least my waterworks are flowing!!!
