Water pump won't stop running. (2 Viewers)
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Through a very kind Funster I took the motorhome to a lovely man near Limoges yesterday. He sorted a couple of things for me and changed the gas over to French.
However, when we filled it with water and switched the pump on, it wouldn't switch off. Just kept running even when we turned taps off. Phoned the dealer where I bought it and they said it could be small leak that makes the pump think it still has to keep running--but I can't see any leaks from taps, pipes under the worktop, under the bathroom basin.
I have to find someone here who can look at it--not easy in the middle of nowhere (or so it seems at times) Just wondered if anyone had any ideas of what it might do, so that if I find someone and they start to tell me "stuff" I might be able to make sense of what they are saying.
Sorry--does this make sense?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Internal pump leak such as diaphragm may cause this problem so no leaks to see as such. Make and mode of pump may help others to help you
Geo
11,842
14,071
It would also be useful to know whether the pump runs continuously or cycles on and off. If it runs continuously and there is a leak then it is a big leak then there will be lots of water so you should be able to find it. It may well be a fault with the pump as Geo says in which case it would be worthwhile replacing it. Some of them can be serviced but if you have to pay someone to do it then it may be cheaper just to replace it.
Hollyberry
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Geo
Thanks, The pump just runs constantly--doesn't stop or pause and restart.
It says Superflow 126 PRO on it. Does that help at all?
I can't see any water leaking anywhere at all and there was none yesterday either.
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
It could well be the pressure sensing switch stuck or faulty, give the pump a tap with a hammer (not too hard!)
Temporarily you can switch it off by removing a lead
Peter
Hollyberry
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
I'll try the hammer--gently, wrapped in a towel I think.
[HI]Temporarily you can switch it off by removing a lead[/HI] Do you mean switch off the pump or the sensor?
There is water in the tank. & can't see any leaking in or outside m/home.
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
If you have a separate switch for the pump, use that.
The pressure switch is on the end of the pump where the wires are connected, you may be able to adjust it, (cant remember!)
Peter
ehuplad
504
93
North Yorkshire
Hobby 600
Is there water coming out of the taps ?? has all the air been bled out of the system?
11,932
9,092
Right then :Smile:IF after tapping with hammer fails,next is adjust pressure switch and if that fails you have two choices get a repair kit (quite cheap) or fit a new pump :thumb:
Once you remove the pump get the hammer again and smash it to bits (feels good ::bigsmile:)
terry
Hollyberry
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Thanks. It's under warranty still from purchase of van. Will try the hammer tapping later and see what happens.
You've all given me plenty of clues and alternatives so hopefully it'll be fixed/replaced if necessary soon.
11,932
9,092
:Doh::Doh::Doh: Why did you not say it was under warranty ::bigsmile: HOPE the tapping hammer works that way you don't have to go back to dealers :thumb:
terry
aba
2,775
1,112
yorkshire
dec 2009
if its not on a pressurised system one of the switches under one of the taps could be faulty.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
I agree, does sound like a faulty microswitch could be to blame. If they do not go 'off' fully, the tap will stop running water, but the pump will continue, even if no water is coming through. Cost about 30p.
11,932
9,092
The Sureflow should be used on a pressurised system :thumb: When did you last buy micro switches ?The last I bought about 7 /8 yrs ago were around 4 quid ::bigsmile:
just looked on ebay £3.50 each :winky:
terry
Hollyberry
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Thanks for all your suggestions. Now managed to find mechanic who has come out to the house (going to motorhome place recommended involves 2 and a half hour drive each way) he thinks it is a loose connection or possible a dodgy switch. But he can fix it!!!:Smile:
It's still under warranty but don't really want to drive from Dordogne to Southampton if I can avoid it.
And I so wish I had a fraction of your mechanical knowledge.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Be careful what you wish for.
My mechanical knowledge gets me into far deeper s**t, than your lack of it ever will:ROFLMAO::ROFLMAO:
Geo
rainbow chasers
3,680
1,725
Mid Cornwall
Various
terry
I only paid 30p last year - either they messed up, or I am going to start selling them on Ebay! :ROFLMAO:
Scout
3,959
121,359
South Yorkshire
chic c line
how long has it been running?
on the first fill up of the year (from dain down) it takes a while for the hot water tank to fill , are you sure its not just that? it could take up to ten minuettes runnig
Hollyberry
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
It was going for more like half an hour. There's a wire that seems loose and when Mechanic Man wiggled that it stopped. He said something about a microswitch (?) that might need changing. He reckons it's fixable quite easily so hopefully be on my way soon.
Scout
3,959
121,359
South Yorkshire
chic c line
yes 1/2 a hour is too long to just be filling up the hwt, I hope its just the ms
Mar 27, 2016
192
681
Melton Mowbray, UK
Hymer 408
Since 2016
Brilliant thread - just fixed ours. We were panicking in case there was a real problem, wiggled the wires shook the pump and we are now very happy campers again
Angel Taskovski
4
RV Hi Top Alcove
I am newbie
I have same pump. Can someone explain what is micro switch under tap? or post a photo of it? What is role of this microswich?
19,368
30,326
Basically you have two ways of controlling the pump,
1/ with a pressure switch on the pump it knows when a tap opens and the pressure in the system drops so it switches the pump on until the pressure builds up again.
2/ the other way is to have a switch in each tap that switches the pump on when it opens, you can tell if you have this type as there will be wires under the tap as well as water pipes.
Jun 17, 2012
2,934
9,935
North Essex
Autotrail Delaware
>12 but <13
I had same problem as we arrived in France. Traced to faulty micro switch in pump. Sometimes didn't work at all. Pulled wires from switch and joined them (used a 10 amp fuse as a link (y)) then switched pump on and off from panel. .
Located switch on ebay, paid, changed delivery to my friend and he delivered to me in France a couple of weeks later. Installed switch in 10 minutes. Ensure pump off and taps open.
Angel Taskovski
4
RV Hi Top Alcove
I am newbie
Thank you a lot for your advice. I checked seams like there are no wires under sink tap. Tomorrow i will check if it was all about oxidated connections on pressure swich. Visually they look oxidated and tomorrow i plan to clean them and connect pump again.
19,368
30,326
That sounds like a plan(y)
