Can anyone tell me if there is a cure for the noisy water pump on my friends fourwinds 5000.
Can he get another one thats quieter fitted or is their any way of dulling the loudness.
This is common problem on RV's and is caused by inherant pump vibration being magnified as it travells down the rigid piping.
You can buy a sound deadening kit which is basically two "soft" rubber pipes which connect either side of the pump and onto the ends of the rigid pipework.
alternatively, if you're tight like me, you'll "obtain" two lengths of hose pipe and some jubilee clips to do the same job at a fraction of the cost.
You MIGHT want to use food grade pipe - personally I didn't bother.........and I'm still here
You MUST use reinforced pipe because the pump pressure is enough to blow ordinary soft pipe.
Also, do NOT fit a fiamma/shurflo/ whale or ANY other "euro" pump to an RV.
The flow rate and pressure cut off on pumps supplied for european vans is MUCH less and your tap pressure, especially the show will be useless if you try.
They ARE usually cheaper, but it's just no worth it........believe me, I tried!:Blush:
Has anyone had any experience of fitting an accumulator in the water system. Do they have any effect on pump noise and do they allow the pump to work less?
Our RV has the water pump under the bed (with the water tank) and although not that noisy, sounded really loud at 2 o'clock in the morning if you flushed the toilet. I fitted an accumulator (5l size) and now turn the pump off at night and just use the pressure in the accumulator. Result- silence, but still able to flush the toilet and use the washbasin. It also, as previously mentioned, evens out any fluctuations in the shower, etc, if someone turns on another tap elsewhere in the RV. Pump runs in short bursts to restore pressure, but flow is constant. Can definitely recommend one.Has anyone had any experience of fitting an accumulator in the water system. Do they have any effect on pump noise and do they allow the pump to work less?
