Water pump help please (1 Viewer)
Feb 26, 2013
1,653
9,408
Pinar de Campoverde, Spain
Giottiline T60
Since March 2013
We noticed our water pressure seemed fine from the bathroom sink but slow from the kitchen sink and the toilet flush is also slow. We have checked all the pipes and also swapped the pump for our spare to no avail. Does anyone have any ideas what could make the pressure low to only parts of the system? :Eeek:
Zepp
1,673
3,260
Roaming
7 Years
Im no expert but you may have a air lock in the system also is the pump coming on when you switch the kitchen tap on if not could be a duff micro switch on kitchen tap
43,330
49,446
Flow rate can only be a partial blockage or a leak.
It may be the new tap is faulty, maybe the wrong bore size or manufacturing debris inside it. but that wouldnt explain the slow toilet flush
Jul 29, 2013
9,071
18,539
Salisbury
Hymer B678DL A class
since 2011
We had same sort of trouble ended up being the toilet apparently the solenoid was faulty didn't even know it had one!
Coolbeanz
Feb 26, 2013
1,653
9,408
Giottiline T60
Since March 2013
The tap is ok, it was new last year and worked fine. @Munchie had a good idea and suggested we blow back down the tap to see if it clears anything. If not we'll dain down and re-fill. Hopefully a pesky little air bubble somewhere!
Coolbeanz
Feb 26, 2013
1,653
9,408
Giottiline T60
Since March 2013
All sorted!! It was a pesky air bubble hiding down a pipe somewhere. The toilet flushes so good it does next doors toilet too now :rofl:. Better go and mop the bathroom as the air bubble came out with great force followed by a shower :doh:
May 29, 2013
2,598
19,235
Tyneside
Chausson best of Flash 10
Several years now
Just like the next morning after 8 bottles of Brown Ale !
Jul 24, 2010
535
4,143
Planet Earth (I think)
not long enough
Good that it's sorted. Off topic... Kerry I have missed you! I love reading your blog and seeing the fab photos. What has happened? how was Goa? Where Are you now? Most importantly... When will the blog be updated??
Lorraine x
Coolbeanz
Feb 26, 2013
1,653
9,408
Giottiline T60
Since March 2013
Lorraine x
I have been feeling really guilty at neglecting the blog!! We had so much going on with the house sale. I plan on doing an update on the last 6 months and now we are touring again I will do my usual monthly blog. Watch this space :D
Coolbeanz
Feb 26, 2013
1,653
9,408
Giottiline T60
Since March 2013
We restarted the whole process of drawing the water through the hot taps first and then the cold and all the air came out. Hubby thinks he forgot to bleed the hot side first :doh:
