Water Heater Not Igniting (3 Viewers)
RS_rob
1,010
669
Turnford
Hey all my Carver Cascade Rapid II is not firing up
im getting a red light next to the flame icon on the control panel.
The book suggests an air lock & to repeatedly turn it on which I have been doing all weekend.
Any ideas of what to do..................................
43,330
49,486
Ignitor board or gas valve failure.
I guess you need to get into the works to see if theres a spark and check for gas at the burner.
RS_rob
RS_rob
1,010
669
Turnford
Swap LPG cylinders sometimes works, especially if tank is low.
Assume you've not done what we did one weekend and left the cover on :doh::doh:
Tried that switched to a full cylinder & no joy, also tried it again when we got home & still no joy.
RS_rob
RS_rob
1,010
669
Turnford
Silly question I know, but have you removed the flue guard?
I haven't touched anything on it, would this be the plastic cover outside
RS_rob
RS_rob
1,010
669
Turnford
right will try it after work tomorrow
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Do you have a window open over the exhaust as that will stop it working as it has an inhibitor switch.
RS_rob
RS_rob
1,010
669
Turnford
If you guys mean a separate cover that goes over the vent I do not have one, the only cover is the actual vent, I can go & unscrew it.
Dazzlin
1,751
6,213
La Marina, Costa Blanca.
1986 Hymer A Class
From 2013
Try the gas regulator. We had the same symptoms in spain. Fridge and hob still working but red light when trying to get hot water. Replaced regulator and bingo!
Thanks to @seanoo
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
Have you had it lit before? Simple things like gas isolator etc. Can you hear it trying to light?
RS_rob
RS_rob
1,010
669
Turnford
Thanks to @seanoo
will do everything else works hob, oven, fire, fridge & last used 3 weeks ago would have been less if id have had my way.
I actually have a spare regulator new a few months ago to power a bbq we returned.
RS_rob
RS_rob
1,010
669
Turnford
Got home to late to do anything tonight but my guess is my agency will drop me Wednesday with no warning.
RS_rob
RS_rob
1,010
669
Turnford
Update: 26/10/15
it seams to be an air lock hopefully (y)
we are on EHU in Norfolk & been here well over 24hrs & tested the gas today & it worked 1st time.
All good no red lights & heat coming from the vent.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Hope thats you got it sorted. Enjoy your time away.
23,836
72,507
If we do not use the gas option on ours for a week or so it rarely lights first time..
Always have to wait for the error code, turn it off and turn it back on..
Tried all sorts and then spoke to others with the same vintage set up as we have.. They get the same !
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Has it been serviced Lately?. Stuff like Spider webs etc; can cause misfires and the like. Our fridge for example. stopped working on gas, Cause was rust from the vent had dropped onto the Burner. Intermittent faults can be temporarily "Cured" by having driven the van and shifted "debris".?
BTW, The genny on the r-v stopped working, Cause was a Clump of debris left behind by a "mudspider" nest!! (not found in the UK though)
Pete
