Water Heater Not Igniting
Discussion in 'Motorhome Chat' started by RS_rob, Oct 18, 2015.
  1. RS_rob
    RS_rob Funster
    Dec 14, 2013
    889
    607
    Turnford
    Hey all my Carver Cascade Rapid II is not firing up
    im getting a red light next to the flame icon on the control panel.
    The book suggests an air lock & to repeatedly turn it on which I have been doing all weekend.
    Any ideas of what to do..................................
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    Ignitor board or gas valve failure.
    I guess you need to get into the works to see if theres a spark and check for gas at the burner.
  3. Allan & Loren
    Allan & Loren Funster
    Dec 8, 2014
    1,377
    2,006
    Leyland, Lancashire
    Swap LPG cylinders sometimes works, especially if tank is low.
    Assume you've not done what we did one weekend and left the cover on :doh::doh:
    • Like it Like it x 2
  4. RS_rob
    RS_rob Funster
    Dec 14, 2013
    889
    607
    Turnford
    Tried that switched to a full cylinder & no joy, also tried it again when we got home & still no joy.
  5. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,627
    2,810
    Surrey
    Silly question I know, but have you removed the flue guard?
  6. RS_rob
    RS_rob Funster
    Dec 14, 2013
    889
    607
    Turnford
    I haven't touched anything on it, would this be the plastic cover outside
    • Like it Like it x 1
  7. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,627
    2,810
    Surrey
    Yes, if that is still on, then you will get the symptoms you described
  8. Allan & Loren
    Dec 8, 2014
    1,377
    2,006
    Leyland, Lancashire
    That's what we did, drove us bonkers all weekend!
  9. RS_rob
    RS_rob Funster
    Dec 14, 2013
    889
    607
    Turnford
    right will try it after work tomorrow
  10. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,452
    1,767
    Dover
    Do you have a window open over the exhaust as that will stop it working as it has an inhibitor switch.
  11. Mi58ck
    Mi58ck Funster
    Aug 9, 2012
    130
    117
    Worcester
    I also failed to remove the cover.lol
  12. RS_rob
    RS_rob Funster
    Dec 14, 2013
    889
    607
    Turnford
    If you guys mean a separate cover that goes over the vent I do not have one, the only cover is the actual vent, I can go & unscrew it.
  13. RS_rob
    RS_rob Funster
    Dec 14, 2013
    889
    607
    Turnford
    All closed & no switches on the windows.
  14. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,627
    2,810
    Surrey
    Take a photo of your vent and post it please.
  15. Dazzlin
    Dazzlin Funster Life Member
    Oct 31, 2012
    905
    1,819
    on the road
    Try the gas regulator. We had the same symptoms in spain. Fridge and hob still working but red light when trying to get hot water. Replaced regulator and bingo!
    Thanks to @seanoo
  16. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,616
    2,657
    Trowbridge
    Have you had it lit before? Simple things like gas isolator etc. Can you hear it trying to light?
  17. RS_rob
    RS_rob Funster
    Dec 14, 2013
    889
    607
    Turnford
  18. RS_rob
    RS_rob Funster
    Dec 14, 2013
    889
    607
    Turnford
    will do everything else works hob, oven, fire, fridge & last used 3 weeks ago would have been less if id have had my way.
    I actually have a spare regulator new a few months ago to power a bbq we returned.
  19. RS_rob
    RS_rob Funster
    Dec 14, 2013
    889
    607
    Turnford
    Got home to late to do anything tonight but my guess is my agency will drop me Wednesday with no warning.
  20. RS_rob
    RS_rob Funster
    Dec 14, 2013
    889
    607
    Turnford
    Update: 26/10/15
    it seams to be an air lock hopefully (y)
    we are on EHU in Norfolk & been here well over 24hrs & tested the gas today & it worked 1st time.
    All good no red lights & heat coming from the vent.
    • Like it Like it x 3
