water filler cap wont stay on (2 Viewers)
Scout
3,959
121,330
South Yorkshire
chic c line
Ive just filled up with water, the filler cap came of ok (push in twist anti clockwise ) but wont go back on,?
It just turns and wont grip?, Im currently try the "soke it in boiling" water trick, I did it once for about 10 mins and it didnt work, should I have left it longer? or is it knaXXerd. If I need to replace it, would it be better to repalce the whole unit or just get a new cap, there does not seem to be any damage to either part. It does seem to comprese ok, the lock does turn with the key.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Are you sure it hasn't locked, tried it with key in both positions?
If you need to replace it you can swap the lock barrel over
Scout
Scout
3,959
121,330
South Yorkshire
chic c line
Ive read your earler posts suggesting that so I did try it with the key position both ways, I soaked it twice but to no avail. the only thing I didnt do was wipe it round with silicon spray, Ive got some wd40 will that do?
there seems to be a lot of very simular caps about, olearys have one thats universal? any ideas if there any good
Techno
Jul 28, 2010
15,475
20,756
May 2010
Silicon it the right thing to use. Its very odd that it spins freely as that would indicate it is either locked or broken if unlocked.
Have you a picture of it?
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
To be honest it can be a bit of a phaff some times but usually its because the you're trying fit it with it locked.
Techno
Jul 28, 2010
15,475
20,756
May 2010
BTW boiling water is to free a cap that's seized . Yours has not seized just the opposite
53,448
150,066
Had problems with our diesel cap (same as water cap) soaked it in hot water took it apart and reassembled it, couldn't see what was wrong with it but its not gone wrong since.
Scout
Scout
3,959
121,330
South Yorkshire
chic c line
if i grip the inner core I can twist the outer part no matter which way the key is turned, Im asuming anti clockwise key postion is unlocked and clockwise postion shoul;d be locked
Techno
Jul 28, 2010
15,475
20,756
May 2010
Should only be able to twist it when locked. It should all turn together when unlocked.
You actually have the opposite issue to the usual fault where it seizes together so locking it has no effect.
Scout
Scout
3,959
121,330
South Yorkshire
chic c line
so mine is broken then? I thoght so,
Ive just poped over to Marquis Motorhomes at dinnington they had one in stock £9.99 plus a bit of deisel fitted in less than a minuette all working ok, how easy is it to swap lock barrels over.
Reactions: CWH
Techno
Jul 28, 2010
15,475
20,756
May 2010
If it has a Zadi lock 1 minute with the special key
Techno
Jul 28, 2010
15,475
20,756
May 2010
Which one does yours look like in the ebay link I posted.
The first five for example all have a red shutter
Scout
Scout
3,959
121,330
South Yorkshire
chic c line
it looks like number 2, key is double sided like the origanal
Scout
Scout
3,959
121,330
South Yorkshire
chic c line
Still room at Hartlepool (next week) marina and Malvern
next weeks bad week for my chemo...I'll be in qurranteen (low white bloods cells), but Im sure we will chatch up sometime, its not in a hurry....
Techno
Jul 28, 2010
15,475
20,756
May 2010
First unlock it then insert red key and pull (y)
Tinbum262
Hymer B
Message for Techno funster, firstly thank you for the advice/pictures showing how to replace ZADI drivers door barrel with the aid of a ZADI removal key. Your advice was for a Rapido, but it worked on my Hymer. I had been fiddling for about 8 hours before a kind person pointed me to Motorhome fun, where I found your pictures. Secondly, your advice please, I cannot remove the ZADI barrel from the water tank cover access point. It is spring loaded inwards, I unlock, remove the usual key, insert the removal key and wiggle it and it will not come out. Any thoughts very grateful. Tinbum262
Techno
Jul 28, 2010
15,475
20,756
May 2010
I can only imagine it is the same procedure as for hab door lock.
