water draining
Discussion in 'Motorhome Chat' started by alcorn54, Apr 1, 2011.
  1. alcorn54
    alcorn54 Read Only Funster
    Nov 21, 2010
    283
    6
    Co Durham
    sorry I know this is a repeated post ,but its doing my head in,I have found the fresh water drain tap under a floor trap behind passenger seat and in front of the water tank,it looks like a simple on off tap with clear pipe straight out the bottom . But !! when open a little water comes out then stops ?? Ive traced pipe back and it goes to a small black box with a clear cover on the side of the water pump ,is there a special way to start drain off ??.
    The only way at the moment I can seem to empty water tank is to open dump valve and turn pump on. Alan
  2. dazzer
    dazzer Read Only Funster
    Jul 30, 2007
    1,698
    99
    In my house
    If it works .......... do it!!!!
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,332
    34,813
    May be a daft question, Alan, but have you tried contacting the maker. There is an e-mail address for the parent company Here and phone numbers for the UK agents Here.
  4. alcorn54
    Nov 21, 2010
    283
    6
    Co Durham
    Yes ,at least 4 times no reply,the phone number for UK agent goes dead Emm Bee have said if I have drive over they will have a look for me but it a bit to far to go .
    Now sorted,
    opened valve up in dining area then crawled under van and literally blew up the pipe,felt it was blocked and then something give and I could feel air going into tank. as soon as I stopped blowing out came the water!! must have been blocked some how? the breather pipe on side had a kink in it as well so wondering if it was fitted properly and tank was pressurizing up,because as I took internal lid of on inside it literally poured out, taps seem to run a lot faster as well Ive cut 4 ins of breather pipe and this has took the kink out ,its probably been this way since new!!.Alan
