Waste water carrier. (1 Viewer)
Wurn
73
Hi, we have just taken our first trip as total beginners and had great fun.Took along a notebook to record any bits we would need in the future and picked the brains of some seasoned van owners.Only problem remaining unsolved is what to catch the waste water in when not emptying over a drain etc.The outlet pipe on our Cheyenne is only 170mm. from the ground and all the wheelable or carry ones I have looked at are too high to go under.Am I missing something obvious here? What do other owners use?
Cheers Paul.:Doh:
tucker_j
87
Kent
6 Years
I know this isn't the politically correct answer so I'm sorry, but when we first hired a van the drain didn't work properly and so the only way to empty was to open the valve and drive away. The movement of the vehicle did the trick and we nicknamed the van 'Brian the Snail' because it was slow and left a trail :Blush:
Last year we hired another van which did drain properly and on most occasions we found sites had a suitable dump drain. On the rare occasion where there was not a suitable facility we asked the owner / warden where they would like it dumping and they usually pointed us towards a suitable hedge or ditch.
Without wishing to give us MH's a bad name, if I couldn't drain the tank on site I would look for a suitable public drain or ditch where I could very discretly empty it instead.
43,357
49,636
try a bucket.
use it for other uses as well.
curious!!!!
quote]......The outlet pipe on our Cheyenne is only 170mm. from the ground. [unquote.
where can you buy a bucket that is only 6.5" high.::bigsmile:
this'll get all the environmentalists whinging again :RollEyes:
we empty in the nearest layby with a drain:Blush:
always have...always will:winky:
2,368
10,296
most if not all CL sites are more than happy to dump in the hedge, this is best done with a length of suitable sized pipe run from your drain pipe to the hedgerow , just leave the dump valve open .. you could also use this pipe to fill a bucket..
Please don't use street drains, they are only for storm water which is drained back to a nearby stream or river so
a) its illegal, you can be fined.
b) if seen, it gets us all a bad name
c) you may pollute a river ..
Jim
W
Wurn
73
Jim
I suppose with experience I wont let the waste water tank fill up when I am all levelled up on site! Thats the reason I wanted to empty it in situ.:Doh:
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
When there's a hosepipe ban they tell us to water the garden with used bathwater.:winky:
What they don't see don't hurt them.:Blush:
43,357
49,636
Jim
sorry Jim, that doesnt hold water, so to speak.::bigsmile:
had this argument a long time ago on here.
cant remember who the poster was but his argument was...... ALL surface water will eventually find its way into a stream/river/culvert no matter how far away.
whoever it was sounded like he was an environmental health or water company man as was very convincing.
if i can find the thread/post ill post it here but it goes back a long way.
Scout
3,960
121,624
South Yorkshire
chic c line
curious!!!!
just dig a hole under were the bucket would go, sorted:thumb:
only kiddin
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
We were on a site a few weeks ago and the lady in the office said "everybody wants to pitch around the perimeter of the site, up agains the hedge, I wonder why"
Errrrrgh, I didnt tell her why.
Jim
:Smile:
Spacerunner
607
197
Hampshire
When you think about all the cr** and oil and road kill body parts that are washed down road drains, then washing water seems quite innocent!
The thing with disposing of waste water under a hedge is that soil acts as a natural filter. By the time the water reaches a water course its virtually pure water apart from the sheep dung, worm slime and mole cr** its picked up on the way through. :winky:
May 22, 2008
484
I notice lots of people have a small bucket or used tile grout type bucket with holes drilled in the bottom, they fill the container with grass and place this under the waste outlet of their vans so that waste water trickles into it, gets filtered and the cleaned water seeps into the ground. At their departure they dump the used grass in a suitable way and bobs your uncle. Rocket science or what.I also notice others have a more soffisticated version of this IE they make up a system whereby they have plastic pipe used in drain laying with screw off entry point to put the grass in and a length of hose attached to connect direct to the waste outlet of their vans.The 4 inch pipe is drilled and this allows water to seep out.:Eeek::Eeek:
cobmonster
56
Wokingham, Berkshire
9 years
Cheers Paul.:Doh:
I have the wastemaster container which is wheeled and can carry the toilet cassette also. The wastemaster has several caps at different levels to be adapted to the required hieght.:thumb:
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
This is exactley what I do. Its no problem whatsoever and avoids ground and water contamination as Jim eluded to and rebuked by hilldweller.
SAVE OUR FISH
Jim
:winky:
bevo
218
4
north west
c class
bucket
waste pipe 170mm high.
you do what i did on my sundance.
drill a hole with a hole saw 170mm high.
sounds simple to me.
Jim
:winky:
Rebuked ?
REBUKED ??? By me - never, it was a question.
Tell me have you ever washed your car ? God forbid you have ever washed your MH, unless of course you did it in a huge plastic tray.
I really can't see a significant difference in pollution. Then think of the dear farmers, have you seen what they spread on the roads ?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Top Tip
Seen at a couple of shows now and thought it was the dogs wotsits. A plastic tray small enough to fit under the outlet pipe was filled with grass as deep as possible. waste water is then filtered though it direct into the ground, at the end of the show/stay or what ever the box is emptied into a plastic bag and placed in the rubbish bin. Job done.
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
Waste water carrier
:thumb:Hi,I have a Cheyenne and have just bought a waste hog it
just fits undereath outlet, with a little persuasion .
best regards
Mike.
Scout
3,960
121,624
South Yorkshire
chic c line
never mind the roads......what about the fields.
ask anyone at the fishing meet last weekend what the air smelt of......
pig sh*t.
never mind the fields, what about my windscreen, itll take me age to get rid of it
Wall-E
38
Collecting waste water?.
Hi Wurn,
My waste tank outlet is also quite low, more so because the discharge pipe elbow is facing straight down. I find that most pitches are not level and in leveling up the motor home on pads, it raises the outlet up a couple of extra inches. I use one of the smaller round, rubber, rubble buckets ( Type with two loop handles) and empty it every day or as required. The advantage of this type of pliable bucket is, if you forget it,s there and drive off, it doesn't cause any damage underneath the M/H. The buckets are obtainable from B&Q or garden centres. I can't think whats difficult about emptying it!!.
Wall-E.
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
Tell me have you ever washed your car ? God forbid you have ever washed your MH said:
Exactly.:thumb: Let's not get too carried away with the P.C. thing or else we wouldn't start up our 'gas guzzlers' in the first place. If we are to be ECO Warriors best we bin all the 'Yank tanks before worrying about dumping a wee drop of Fairy liquid down a gully. Think about it.:RollEyes: You know it makes sense! :winky::ROFLMAO::ROFLMAO::ROFLMAO:
