Waste Pipe Leak (1 Viewer)
Jun 22, 2014
558
748
Great Totham
PVC
Since 2015
Hi,
The grey waste pipe that runs under the van to the waste tank. Is this supposed to be only a push fit? Over the weekend my wife was having a shower when I noticed it leaking from under the van only to find the pipe had come apart at a join where it pushes into an elbow. I pushed it back in a seemed to be ok but just wonder if they are just a push fit or should have solvent cement.
John
GJH
29,450
38,827
None, now sold
2006 to 2022
There are various different types of grey waste piping arrangements. I think rigid pipes are either push fit or glued whilst those using convoluted pipe have a jubilee clip to hold the pipe on. Some may be push fit to enable it to be taken apart in case of blockage.
If it is a push fit that has worked loose with age maybe some duct tape would hold it.
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
I wonder if maybe it has been disconnected on purpose to allow cleaning (grey water is amazingly gungy, I know from my own issues with blocked pipes), could also have been done to allow the shower water to go straight to ground when wild camping maybe, save over filling the grey water tank
But I agree with all GJH says, various styles types sizes, could simply have come loose :)
Is your MH the Swift Bolero on your Avatar? Maybe someone will have the same, problem or MH at least (y)
John and Jo
Jun 22, 2014
558
748
Great Totham
PVC
Since 2015
Cheers guys ...yes it is a swift bolero. I'd reckon it was just assembled as push fit. Was just wondering if they are just pushed fit as part of assy process or it should have solvent cement and was missed out in assembly.
GJH
29,450
38,827
None, now sold
2006 to 2022
Reading your OP again, the fact that it is a joint at an elbow makes me think it probably is a push fit, for the reason that David gave. Elbows will be one of the easiest places to become blocked with any gunge.
Gayle99
7
3
Stranraer
Swift Bolero 684
I'm a newbie
We have just bought a bolero and on our first trip noticed the waste pipe was loose. It had been fine when we purchased but think it probably detached when we took a steep right angled bend a bit tight. (Still learning). Mick pushed it back and it seems fine now. Bought jubilee clips and gaffer tape just in case though.
3,201
229,569
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
We also have a Bolero and our is push fit.
Makes it easier if/when there is a blockage (y)
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Hi,
John
I would be a little careful just pushing it onto the elbow if the remainder of pipe (on the other side of the elbow) goes into the van and you can't see what else you are moving under your shower tray as you try to push, possible causing more problems, if the elbow and pipe on the other side can be seen then no probs
