Washing on tour for Possers (1 Viewer)
GJH
29,450
38,827
None, now sold
2006 to 2022
We have a limited amount of space in the van wardrobe so need to wash clothes on longer trips. No problem (apart from cost) if staying on a site with a laundry room but what do you do when those facilities are not available?
As it happens, Jill's parents bought a Link Removed some years ago so we borrowed that for a trip earlier in the year. It worked but was hard work and a bit of a pain so we wanted an alternative.
Also as it happens I had a couple of 5 gallon bins in the garage left over from home brewing many years ago. With the addition of a large plunger bought from Poundstretcher for 99p, suitably modified to make a posser by the drilling of two holes in its rubber bit, we have a "washing machine" in which we can both wash and rinse. Works fine, especially (so Jill tells me) if you leave the clothes to soak in a bio liquid solution for a while before possing and rinsing.
scotjimland
2,324
10,065
A Woosh bang
Good solution .. ( no pun intended ) :thumb:
another idea, along the same lines;
while on the move, we used to soak laundry in a plastic linen bin stood in the shower cubicle .. after a days travel, rinse in the shower tray then hang out ..
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
All you need now is a few goats and some black stuff to earn a few bob with.
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
Mrs Callumwa in action at the local launderette.....
No worries when we are travelling...
No Dot Cotton or coins required......:thumb:
May 16, 2010
3,213
2,535
North Hykeham
Custom
much more now
Graham I think it's great to see that the spirit of UK invention is still alive and kicking in the 21st century...:thumb::thumb::thumb:
callumwa
4,110
4,480
In the second picture is the wooden thing what she hits you with to remind you who's boss???:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Trust me...... it works.......:RollEyes:
and it cleans the clothes well too....... (that's not the delicates cycle of course):thumb:
43,329
49,444
a much better solution and not anywhere as labour intensive....
a friend of mine had one a few years back as his ONLY washing machine and swore by it !
The WONDERWASH.
takes a 5lb load....
put in hot/warm water and a little detergent, screw on the lid and tighten the pressure valve.
turn the handle for around two minutes then drain via the removable spout.
a quick rinse then hang to dry.
works on the principle of hot water in a sealed container will increase in pressure to force water/detergent through the clothes.
i believe no longer available in the uk but some are listed on ebay etc or can be bought in america for around $40.
retailed in the uk for around £35.
small and light...around 6lb
G
GJH
29,450
38,827
None, now sold
2006 to 2022
Ours washes plains and strips as well as dots - and other fabrics as well ::bigsmile:
Nowt to do with the spirit of invention, all to do with being tight :ROFLMAO::ROFLMAO:
scotjimland
2,324
10,065
A Woosh bang
My mum and dad had one for camping .. :thumb:
here but, temporarily out of stock
Link Removed
Feb 27, 2011
14,737
75,976
UK
Self Build
The WONDERWASH.
I had one of those. Used it twice and ended up giving it away. Pain the the backside, the back and the arms and left your clothes dripping wet. I can't remember who I gave it to no but I haven't heard anything from them :ROFLMAO:
Prefer the twin tub I have now :winky:
43,329
49,444
Link Removed
while searching for info i found quite a few sites were out of stock....one or two were on the ball saying they dont know when, if ever, they will get stock.
one supplier went as far as to state they are no longer available in the uk and they couldnt restock.
JJ
Mágica
May 1, 2008
19,259
48,046
Burstner Privilege T
over 50 years
I agree with Karl (Grommet)...
Wonder Wash useless...
I reckon if one is using "pressure" to force anything through anything then there has to be a pressure DIFFERENCE between one side and the other... so if you are forcing water through material (clothes) the pressure one side has to be lower than the other. How does sticking clothes in a tub, sealing it and pumping it up push the water through the clothes? :Doh:
Anyhow, it took up loads of space, loads of water and didn't work. Maybe I was doing it wrong.
Anyhow I now have a solution... takes up no space... uses no powder... uses no water... and you still have clean clothes...
Do what Jack Reacher does... when your clothes are too dirty for use... buy new ones and throw the old ones away... :ROFLMAO:
JJ :Cool:
scotjimland
2,324
10,065
A Woosh bang
JJ :Cool:
Brownian Motion and Fourier’s Heat Equation
Brownian motion is named after Robert Brown, a Scottish botanist who discovered
the phenomenon in 1827. :winky:
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
it dont say that in your link jim:Smile:
it says you have to put it under pressure(you have to shout at it):ROFLMAO::ROFLMAO:
scotjimland
2,324
10,065
A Woosh bang
well, I can't be held responsible for that now can I .. :Doh:
The wording in the link is no doubt written in such a fashion as to be understood by non technical people .... if the scientific principal, Brownian Motion and Fourier’s Heat Equation was given most just wouldn't understand ... :winky:
Aug 29, 2010
845
1,251
Nuneaton. Only when I have to.
Hymer Exsis t564
Since Sept 2010
Slightly off topic but...... At a campsite we stayed at in France recently they had a vintage wringer (Acme brtitish made in the fifties I guess) by the laundry sinks. Thought it was a great idea to help with hand washing and it was well used. Would be great if more sites followed suit!
Heyupluv
3,862
1,593
France,
touring many years..42+
John here is one for you
Link Removed
But surely this is the modern way to go....or the one I would buy
Link Removed
Mel:thumb:
staging lady
1,131
55
North Wales in the Hills
6 years but caravan owner in past
GJH;465941 Also as it happens I had a couple of 5 gallon bins in the garage left over from home brewing many years ago. With the addition of a large plunger bought from Poundstretcher for 99p said:
What a brilliant idea but- what happened to the home brewing? We've just started with home made hock glugging quietly by the stove.
I find the travel washing gel in a tube " Genie" great in the van. It's light,small to store( in a tube)and very effective. You can get it in French supermarkets
Lucille
callumwa
4,110
4,480
Brownian Motion, quite appropriate....:thumb:
It's because of that stupid Brownian Motion, I now have to wash my underpants more often than I used to!:Eeek::Eeek:
Carol
14,051
112,114
North Wales.
A couple of years ago when I got fed up of using Laundrettes I started just leaving things to soak in a bucket overnight and a good camping rotary clothes dryer (takes very little room), and even if we are away for 3 months no trouble at all. (my only wish is to find a very small lightweight old fashioned wringer) I would be sorted then.
G
GJH
29,450
38,827
None, now sold
2006 to 2022
Used to do it in our last house but nowhere suitable in this one - which we moved into only 19 years ago ::bigsmile:
Lucille
Doesn't that gel taste a bit funny when you brew it though? :ROFLMAO::ROFLMAO:
G
GJH
29,450
38,827
None, now sold
2006 to 2022
Funny you should mention an old fashioned wringer, Carol. We're both sure that we had a small one that we could use on a worktop (with suckers on its feet) in the first few years of our marriage but no idea what happened to it and can't find anything like it anywhere.
We bought a rotary dryer at Newark in March and it works very well.
