warning sign on dash
Discussion in 'Tech/Mech General' started by david and ann, Jun 2, 2009.
  1. david and ann
    david and ann Read Only Funster
    Jan 3, 2009
    96
    8
    Sax Alicante
    Hola
    Has anyone any idea what the padlock sign is on the dash display of my fiat ducato 2.8jtd is. it caused me great probs when returning back home at the chanel tunnel
    . The ignition would n't work unless i turned it on several times and the sign disappeared. It was very uncomfy as we were at the head of the queue !!
    I assume its a lock out on the engine management thingy but would appreciate any advice on it and what to do. :Sad:
    Kind regards
    David in Spain
  2. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    Hi I had that sisn come up on my fiat 2.3 The fiat dealer said it was because I had started the engine to soon after I turned on the key so now I wait until all the start up lights have gone out leaving only oil battery warning lights only it has not come back on since but I did not have trouble starting ? Peter:thumb:
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,786
    6,052
    Mansfield,Notts
    It signifies that the ECU has not recognised the key code built into the key, its quite a common fault
  4. skylark_irl
    skylark_irl Read Only Funster
    Mar 1, 2009
    51
    Dublin, Ireland
    Hi David,
    I may be wrong - and there will be another more qualified along to correct me soon, but this may have something to do with the security system in Fiats.
    There are 2 different key types - A red (burgundy) and Black Key. The red one is the security key, and contains a microchip which is like a mast key. The black ones are the day to day keys, and unfortunately, they can fail, and this will cause the security system to refuse to work. You might have just got lucky and it worked again, but sounds like you may be experiencing the first stages of key failure.
    Now - if you don't have a red key, you may have a Fiat card with a security code on it, and with this or the Red key, you need to go to your local fiat dealer to get a new key cut.
    Best of luck - and hopefully it does'nt fail again.
    Michael
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    looks like a new key to be on the safe side then.
  6. hilldweller
    Dec 5, 2008
    27,513
    26,612
    Macclesfield
    There is a glass capsule transponder in the key. Does the key rattle ? I guess you may have dropped it and it's moved. You can get in them.
