Warning Light (1 Viewer)
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
Hello can any one advise re. a battery symbol in red on dashboard I have just taken van out of storage and this light was on when I started up and it didnt go out on the way home I have charged the battery up on hook up and its says battery good 12.7v but Light still on when I took van back to storage is this light because its not charging from alternator:Sad:eek:r is it something a little more complex:cry:
43,367
49,718
sounds like alternator fault.
Can you put a meter on the battery then start the engine.
If volts rise its charging...if not it isnt.
Dec 10, 2013
3,425
12,312
South Staffs
Pilote P740GJ
Try giving your alternator a tap with the wooden end of a hammer, the brushes may have stuck.:Smile:
RandallC
1,242
3,488
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
First check the drive belt for the alternator. Check it's there and check the alternator is turning.
Maybe as advised a stuck brush and a tap will clear it but could also be a diode failure etc in the alternator. If you run the engine with say the headlights on is the battery voltage above 14v for a fully charged battery.
Sorry to say if your asking what it could be then there is little option for you. Than to take it to a auto electrician. Having read this not a criticism but an observation.
Good luck.
