Using to many volts on 12v than EHU? (1 Viewer)
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
Just unplugged the EHU and this is reading from box
Aug 5, 2018
1,567
3,513
a
So there we have it.. your batteries are rated at 90ah, and that's the 20 hr rating
90 divided by 20 is 4.5
So your batteries should be able to supply 4.5 amps for 20 hrs
I've assumed they are 90ah each not in total and therefore used half the ah rating so as to only calculate a 50% discharge (safe) from the pair..
23,845
72,883
I am currently on a campsite on the Ile de Re,but last night we were on an aire in Cognac. The leisure batteries went down to 11.9 last night with only a couple of LED lights,tv for a few hours and heating for a few hours. With those on,the Sargent EC450 box said I was using nearly 7amps,but now I am on EHU and with every light on,tv and heating on electric it says I am only using 1.1 amps!
So how can I find out what’s drawing power from the leisure batteries that doesn’t draw when I am on EHU?
The Sargent system is set to deliver 10 amps charge and up to ten amps to the 12v system components when on hook up
It is also set to top out at 13.8 volts which means the system never goes in to bulk charge mode ( a bone of contention as far as I am concerned )
Looking at the figures suggests the Sargent is working correctly
Volts went down to 11.9 last night, but when was the last time you was on hook ?
The batteries are charging with the engine running, but to fully charge a couple of 100 Ah batteries you would have to be driving for 10 or 12 hours
How long had you been driving that day ?
How many solar panels have you got ? Was it a bright sunny day that day ?
Aug 5, 2018
1,567
3,513
a
batteries appear to be fully charged at the moment..
Now turn everything in the van off, lights heating tv etc and recheck the BATTAMPS
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
I had it on hook up for a couple of days last week before we set off for the tunnel Friday night. I have a 150 watt solar panel which fully charged the batteries this morning in Cognac. So all working well apart from something drawing down the leisure batteries.
Aug 5, 2018
1,567
3,513
a
at a guess I would say your twin 90ah batteries would last at LEAST 8hrs from fully charged. with the load the sargent is suggested is being drawn, if you are saying, even with solar, they went flat in a couple of hours, then there appears at this stage to be something wrong with them as the charging seems to be fine.
I don't care whether they were only bought in September last year.. :p
43,398
50,003
Never had anything to do with Sargent electronics but could it need resetting?
A possible glitch and there is no load?
Seems odd if its showing 1.1amps from the battery when on hookup but capable of delivering a higher current and 7.9 when off hookup.
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
They were fully charged yesterday but went flat with use last night obviously when no sun.
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
Will check the batteries when I get back next week. Its just going to limit where I can stay over the next 7 days?
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
I turned every thing off at the reading was this
I
I have four fluorescent bulbs I turned on and the amps went to this with just them on
That seems alot for just those on?
43,398
50,003
Fluorescents are power hungry for what they are.
They run on 230vac so have small, primative inverters inbuilt.
Inverters eat power, even little ones, for what they give back.
Best option with those is remove the guts and fit LED strips inside the casing.
My old RV had nine of them, all twin tube jobs.
In total, all running, almost 24amps.
I had 440ah of battery power but still swapped for LEDs.
Aug 5, 2018
1,567
3,513
a
That's not a good sign..
Can you not switch the fridge over to gas?
Is it a compressor fridge?
As that 0.8 amps could be when it's just "idling" (i.e fridge thinks it's cold enough so doesn't power up).. When the compressor kicks in though... :eek: That'll be where your battery power is going (most likely) if it is running and is a compressor type..
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
Turned everything off including fridge and still reads 0.7 a
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
No it's not a compressor fridge. Will put it on gas to see if different reading
Aug 5, 2018
1,567
3,513
a
At the beginning Jo said he was using LED lights, so not sure where the flouros came in..
They are power hungry buggers as you say, that is at least halfed his amp draw by not using the flouros but using the LED's instead..
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
But I have always had these lights but never had the batteries drain like they are now.
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
Iv got a mixture of both but only had the led on last night as know they are not so power hungry seein as we were in an aire but still drained the batteries
Aug 5, 2018
1,567
3,513
a
I gotta go to bed.. peace out. try again tomorrow.. :D
Go through every item in the van and jot down the BATT AMPS reading for each.
We'll find it eventually but definitely need to find what's using nearly an amp with everything off..
10 watts.. sounds like a bulb of some sort. perhaps its the power consumption of the actual sargent unit!!!
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
Ok mate thanks for you help?
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
Yes the Sargent box must use some,and the solar controller?
May 31, 2015
11,792
45,007
Ducato PVC
Getting Better
You’ve not got a light in the garage/wardrobe that’s on...? Cab radio, something plugged in charging ..... outside light.. reversing camera ...
‘’climb in the fridge and see if the light stays on when the door is shut...?
just trying to jog your memory....??
Jan 19, 2014
9,413
24,849
Derbyshire
Elddis Accordo 105
since 2014
The heating system may use some even when the main switch is off. This is so the fans can still run to cool the heat exchanger down if you suddenly switch everything off at the main switch.
Jo662
May 7, 2011
6,000
32,094
East Anglia
Kontiki 669
Will check all them in the morning. Good idea about locker lights as got a few those??
53,866
151,733
You forgot the power eater...... The heating fan.
Old wives tail why does everyone blame Truma heaters. When on full blast they draw about 5.5 amps but that is only for a short time once the van is up to temp it drops to less than 1 amp with a CP Plus controller or a little be more with the classic controller.
23,845
72,883
Usually Sargent unit will draw .2 to .5 amps depending on which model it is
All the older systems has a reset calibration mode for current draw, but that looks a later unit..
Does it have a model type printed any where, and do you have a control panel that switches on water etc ?
43,398
50,003
that seems alot for just those on?
43,398
50,003
But they've always used almost 4amps every hour they're on.
4 hours on an evening.......16amps
TV for 5 hours at 2amps....10amps
^^^^^^^^^^^^^^^^^^ 3amps....15amps
It all adds up.
Aug 5, 2018
1,567
3,513
a
Amp HOURS PAPA ?
Yes I'm still awake ????
Good to see we have some info on what the sargent is likely using in standby anyway.
One other thing i thought of while in the shower, is anything plugged in the ciggy sockets on the dash, maybe the satnav or a phone left on charge?
