Leave me alone, I'm tired.
+1.1A when on hookup & -7.9A when off. So the charger is supplying the load & putting a bit into the batteries when on hookup.Seems odd if its showing 1.1amps from the battery when on hookup but capable of delivering a higher current and 7.9 when off hookup.
So am i. ??Leave me alone, I'm tired.
Agreed, I did mention that earlier.the batteries themselves come under suspicion.
Usually Sargent unit will draw .2 to .5 amps depending on which model it is
All the older systems has a reset calibration mode for current draw, but that looks a later unit..
Does it have a model type printed any where, and do you have a control panel that switches on water etc ?
Amp HOURS PAPA ?
Yes I'm still awake ????
Good to see we have some info on what the sargent is likely using in standby anyway.
One other thing i thought of while in the shower, is anything plugged in the ciggy sockets on the dash, maybe the satnav or a phone left on charge?
The lights do not go off in the fridge, they are a really low draw.
The Sargent panel as previously said will pull a small amount.
The fluorescent lights sound like the culprit.
Can you use an led light if you have any?
Is the TV 12v or working on an invertor??
Can you separate your batteries to see if one is pulling the other down ?
Yes our 2014 Elddis just came with a 13.8v power supply. Not very good.I may have missed something in all this helpful advice but the bit that caught my attention was 13.8v. If this is the maximum voltage achieved is it enough to recharge the batteries properly, to me it looks like a maintenance voltage not a charging one. Some years ago I had a motorhome with an ehu charger that churned out a constant 13.6v and the batteries failed after less than 2 years.
At that time there was an argument going on between battery manufacturers and some electrical manufacturers, the nub of the argument was that devices that produced a constant 13.6v should not be described as battery chargers but only as a supply. When I discovered this argument I did some more investigation and bought a proper battery charger (Sterling) and some new batteries, problem solved.
Yes it seems to be the British caravan system, the same on our 2010 Elddis and our 2013 Bailey. Both with a caravan background.Yes our 2014 Elddis just came with a 13.8v power supply. Not very good.
So it would seem Sargent are not the only ones with this 13.8v fixation
Jo662. is there a separate control panel as well as the main box ? There should be..
The 450 does not run a two feed system as I first said... It has a total output of 20 amp max but it runs in intelligently reducing available charge amps as the load ( lights etc ) Increases.
So if you are drawing 7.5 amps you still have a max of 12,5 Amps charging capability
OK, as long as the system is powered on and feeding the control panel a draw of about .3 - .4 Amps would be expectedThat's the one I have yes?
That was my first thought too, but according to Sargent, the EC450 has a 3 stage charger that should charge at 14.4V during the bulk phase.I may have missed something in all this helpful advice but the bit that caught my attention was 13.8v. If this is the maximum voltage achieved is it enough to recharge the batteries properly, to me it looks like a maintenance voltage not a charging one. Some years ago I had a motorhome with an ehu charger that churned out a constant 13.6v and the batteries failed after less than 2 years.
The EC450 has a three stage charger, so a battery voltage of 13.8V while on hookup suggest that either the batteries are still very flat & the charger is still trying to raise them to 14.4V, or they are almost fully charged & the charger is switching to float voltage. It's a 20A charger & as the load + the charging current is only about 10A, it suggests that almost fully charged is more likely.
Sort of. Depends what you mean by 'more'.So on the Sargent box display should it show more amps when on 12v than when it's on EHU?
Celebrate with a bottle or two before bed. That will ensure the need to get up again around 3 - 4am, while it is still dark. Check the voltage then. No charge going in & (hopefully) nothing having gone out for several hours. The batteries will be at their resting voltage & it will give a good indication of their state of charge.Now after having tv and a couple of LED lights on the leisure battery level is down to 12.5v,which I would of thought wasnt to be bad.
If they show around 12.6V having rested for an hour or so & after having run the TV & lights for a few hours, then they are likely to be ok.
Also check the Battery Amps reading. It should be very close to zero - but the accuracy at low levels might be suspect. Use a torch - don't turn a light on!!
How are you going to do that ?Will check when home next week.
When you arrived back at the aire the 14v was displayed because either...
1. There was still good sunlight and the solar was still charging them
2. The engine was still running when you checked
3. You checked immediately on arrival and there was still a large surface charge on the battery (this is my least favourite as 14v for a surface charge is quite high but thought I'd add it anyway)
A fully charged (but rested) battery will be in the region of 12.6 to 12.8 volts.
At 12.5 volts that's hardly taken anything out of them at all.
The reason you were later seeing the 12.5v instead of your previous 14v, I suspect was because it was dark and the solar was no longer charging them..
However, this differs from your post from the other day saying they were at 11.9v.
Now if that was with your 7-8 amp draw being sucked out of the battery at the time of reading that might not be so bad as it looks.
Battery voltage will "sag" under load and give a false indication of how much "resting" or maybe a better phrase would be "reserve" capacity they have left in them.
When you are checking voltage for this purpose, as previously stated I think, the batteries need to be at rest, not powered by anything and not being charged by anything, (and not had a charge by anything for at least 30 mins before hand, otherwise all your random readings will be really misleading..
I'm wondering how your going to check them???? What method are you going to use ??? Why do you need to take them out ???? I'm now convinced your problem is your lack of experience/knowledge (and I mean that in a sincere not criticle manner) and in fact your batteries and charging system is behaving as it should. You could check you still have 2 leisure batteries on board but other than that, I think you would be wasting energy, your energy, not battery energy.I meant I will check the batteries when I’m home. Think best to take them out to check them don’t you think?
