Upside Down Sockets ? (4 Viewers)
Jun 28, 2016
24
6
Liverpool
Ixeo 680G
We have just bought an Ixeo 680 and all of the sockets for plugs are upside down.
Is this right? They say it's not unusual so I am on the hunt to find out why this is?
Any thoughts welcome !!
MC 55 FUN
3,432
6,347
Rural South West Wales.
2015 Majestic 195
Since 20th Feb' 2016
Was it a southern hemisphere import . . . . . ? :eek:
Seriously - just rotate the socket faces if it's an issue.
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
Our Hobby was the same, 240v sockets in the kitchen area were upside down (its a German thing i think) I spoke to the area manager of Hobby about this and he told me that he is fed up telling them the sockets are upside down but they take on notice... I had to take half the kitchen apart to get at mine before i could turn them round the correct way.
BandB
Jun 28, 2016
24
6
Liverpool
Ixeo 680G
They are not low, its the kettle plug that annoys me !
Seems an idea to change the fronts but its behind that needs changing too
Feb 24, 2013
13,086
101,466
Bolsover, Derbyshire
Hymer S800
not long enough
I suspect it is simply due to the fitters not knowing how UK plugs work, most of Europe uses 2 pins which I think can be fitted either way round
2657
In our Globecar the socket is just below the sink/worksurface and is upside down which actually makes it better for plugging in the kettle and hotplate as the cable exits upwards.
Kool Kroozer
1,361
2,228
Always learning
Exactly the same as in ours, sockets above the hob in the kitchen window were fitted behind a window trim that covered the whole window top to bottom, and the actual sockets themselves were behind the trim so had to remove the lot plus shelving, glass heat proof trims all for the sake of turning two sockets around, the screw cap covers which i had to remove to take the window trim out ended up completely knackered - impossible to remove with damaging so had to order 4 more of those, even though they only cost pence it took 2 months to arrive - and we were part of the EU then :LOL::LOL::LOL::LOL:
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
When I had additional Sockets fitted, the dealer asked the probable use for them and adjusted the direction accordingly. Never thought of anything but up the conventional way. :rolleyes: The first socket was for a charger, where the lead came out of the top, so was fitted straight on, the second was for another charger where the lead came out of the bottom of the plug, but would sit in the garage area so was fitted sideways. The new socket fitted by Vanbitz is sideways for the Skybox to sit in the cupboard.
There was a thread recently where someone had to change theirs from straight because the couldn’t fit conventional plugs one on top of each other.
Kool Kroozer
1,361
2,228
Always learning
It did on our van, to plug anything in that was 240v the lead trailing from the plug was heading towards the roof, not good when ya wanna plug a kettle in for a brew :LOL::LOL:
Jan 31, 2009
494
476
Shropshire
10 years +
Would have made the sockets in my Swift much easier to use if they'd been upside down. They were so close to the work surface there wasn't room for the cable. Had to use an adaptor.
BandB
Jun 28, 2016
24
6
Liverpool
Ixeo 680G
Yes its the kettle socket in the kitchen on full view that is the most annoying. Also a socket in the bathroom.
Neither needed to have been fitted upside down as there is plenty of room for wires.
The more I look at the the more they are bothering me. They look silly.
Also I have looked at other sites with new models and none of theirs are upside down.
The boiler has to go back in to be replaced as they have fitted the wrong one!
Think I will ask them to put them right. The one under the shelf I am not bothered about.
Must be a woman thing. And an OCD issue :)
Ridgeway
3,661
6,156
Lausanne
NiBi Arto 85E
I suspect it's Europe laughing at the UK again but it does make you wonder why the UK still has those crappy large plugs that can only be used one way around, you'll figure it out one day....
makems
3,440
27,702
Ingleby Barwick,,Teesside
Sadly had to give up
On our Burstner Elegance half the sockets were upside down and the rest were correct. It was the same with the light switches - some were on when pushd in at the top the remainder were the opposite way round.
Feb 27, 2011
14,741
76,072
Our plugs/sockets are extremely well designed and engineered. Every part of it and every dimension serves a purpose. I got fed up of my French G/F's sockets as they never felt that solid and I was forever disconnecting stuff when I accidentally knocked them.
Lot lover
1,291
1,617
Lot, France
Le Voyageur Integral
New boy
France - some 2 pin only for lighting and little electric stuff otherwise plug has 2 pins and a hole for the earth with pin in socket.
Rest of Yoorp - no idea
Louis
1,204
982
Anglesey
Fiat Ducato Auotrail
6 Months with motorhome(35 years tugging)
Most of the hotels have dangling sockets, new Europe directive - electrocute the Brits :madder:
Apr 11, 2015
5,418
55,257
hull
Laika Ecovip 300
Not socket, but when we bought our van the lightswitch in the bathroom was 'upside down' had some warranty work done, switch now 'right' way up, however, it is at the side of a shelf and it can be switched on by stuff moving in transit, fine if you notice and always remember to switch control panel off, not so good if vn is in storage, thank goodness for solar. Will be changing it again.
Feb 14, 2014
572
6,025
Ainsworth, Bolton, UK
We have the same MH and it drives me mad, especially the kitchen. When you plug the kettle in it sometimes knocks the light on. I was thinking of asking the dealer to change them all. Why have you got the wrong boiler and how do you know its wrong? Hope you're enjoying the new MH. Gary and Janet X
Jul 1, 2012
714
1,817
Nr Whitby
van conversion
On & off since late70s
Oddly ours are at 90degrees so seem to work OK
BandB
Jun 28, 2016
24
6
Liverpool
Ixeo 680G
Update, they are changing them around when it goes in for the boiler job.
Nice to hear all your comments, a very friendly site.
MH 55 Fun - I assumed behind the socket would have to be turned upside down not just the front plate.
Feb 14, 2014
572
6,025
Hi, who is your dealer? You' re not too far from us in Bury. Just wondering if its the same dealer. Thanks
BandB
Jun 28, 2016
24
6
Liverpool
Ixeo 680G
Hi, missed a few replies there sorry.
We used Emm Bee this time and have purchased a cancelled order with everything on it we wanted.
The boiler though has no electric, they have fitted a gas boiler instead of a dual one by mistake.
Carpets didn't fit, they were for a different model so we have to wait 6 weeks for a new order to arrive.
Only teething troubles but they obviously haven't checked it all before dispatch have they? !!!
They did know about the boiler though to be fair, they told us about that.
We had a new Elegance 810 for the last year or so and didn't like it.
Nearly broke our neck getting down steps in the middle of the night a few times! Also not much room to swing a cat or hanging space for clothes. Couldn't watch the TV if the grandchildren came with us as the bed took up space over the seats. There is loads more space in the Ixeo and loads better thought out.
What have you got?
11,955
16,570
As opposed to tearing the flex out of the UK ones?;)
Feb 27, 2011
14,741
76,072
The way uk plugs are designed the earth wire will be the last to come free. That is what I meant by well designed :p .
I have never ever experienced a cable being pulled out of a UK plug if it is fitted correctly. I have tripped over a few in my time and it is always me that gets damaged not the plug/socket.
Feb 14, 2014
572
6,025
What have you got?
Hi, we bought ours from emmbee, ordered it at nec last year and arrived end April. We have the same 680g, love it. Do you know what we haven't checked the carpets, there still in plastic bag. Best try them. Will ask them to change sockets round. Have you been away in yours yet. We have just come back from France, only 2 weeks away though. Enjoy your new motorhome. X
