upholstery/carpet cleaner. (2 Viewers)
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
Hi all just wondering if anyone can recommend an easy yet effective carpet/upholstery cleaner that I can use on both the seats and the fitted carpet. They are not very heavily stained just getting g tired your advice would be appreciated.
D
Deleted member 29692
We have Broken Link Removed Full size base for carpets, whole rooms etc. The top bit lifts off to give you a small (maybe 3-4 inch wide) head great for small spaces and corners and upholstery etc. Highly recommended.
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
Hi, the best product we have found (by a long way) is 1001 from Lidl's. Not had a mark/stain we couldn't remove with it and it doesn't mark/bleach the fabric.(y)
Hope it helps,
Trikeman. ;)
Khizzie
Khizzie
3,794
5,695
since 2002
Thanks for those suggestions so far but I was thinking more of a handheld spray or similar ,I dont have a steamer or electrical cleaning g device.
Khizzie
Khizzie
3,794
5,695
since 2002
Hope it helps,
Trikeman. ;)
Thanks that's the sort of thing I would be looking at.
Silver-Fox
9,269
29,126
Cheltenham Spa
Rapido
im a not so newbie
I think you will need at least a vac that will suck out the wetness and the dirt
I bought 5lts of cleaner off ebay around ÂŁ15 for 5 lts delivered, you then dilute to suit
2,353
10,218
trying to do a big area by hand is a lot of hard work .. and the results may be disappointing..
if you don't have a Vax wet/dry cleaner, or similar,I suggest to hire a carpet cleaner for the day from Rug Doctor
http://www.rugdoctor.co.uk/how-to-use/how-to-clean-upholstery
How to clean around skirting boards, up stairs, upholstery, car and caravan interiors
D
The problem with a spray or similar onto any kind of fabric is lifting it off again.
Agree with the first part of your post completely. Not the second however.
I hired a Rug Doctor once. The carpets looked worse afterwards than before I started. I found it a complete waste of time and went out and bought the Bissel in my link above the next day.
D
The biggest issue you will have with just using is spray is that once you've soaked the fabric or carpet or whatever you have no way of lifting the dirt and excess liquid off of it so it will take forever to dry and the dirt will still be there.
Khizzie
Khizzie
3,794
5,695
since 2002
Thankyou all ,I do have a VAX carpet shampooer so could do carpets with that as it does suck up the water afterwards. I think the problem will just be the seats inc drivers and passengers seats. The only other option is to have it all valeted,but that I think would be expensive.
Silver-Fox
9,269
29,126
Cheltenham Spa
Rapido
im a not so newbie
You should be able to buy a small head for the vax for upholstery
Ebay is your friend (y)
Jul 21, 2013
148
128
Vienne France
VW T4 & MC LOUIS 671
I swear by this stuff i use it in my car and around house so will be doing Elas seating cushins when weathers bit warmer.
Jul 21, 2013
148
128
Vienne France
You can get it at halfords and any good car place. I do car shows with my car so interior has to be of good standard and clean and my seats are sensetive material and it dosent damage it. The stuff is a dryish foam you spray on wait a bit dependent on how mucky then work in with aplicator on top of bottle then wipe of with damp but not soking cloth so dosnt take to long to dry.
Love the stuff its cheep and really works well. We have a doggi so need it lol
joncris
1,101
1,603
Where it matters
Rimor Katamarano 12p +
Yeah! Pampervan its great and good for most things
joncris
1,101
1,603
Where it matters
Pampervan This is what it says on the tin
"Pampervan is a new 'dense gel' concentrate, 1 litre is sufficient to clean your motorhome or caravan 20 times. Cleans all types of caravan and motorhome bodywork and panels, winter build up, tar spots, tree sap, dead flies, glass and acrylic windows, removes brake dust from alloys. All kitchen surfaces including stoves and ovens. All bath and shower room surfaces. An amazing stain remover for carpets, upholstery and clothing. Non Toxic, Organic and Bio-degradable, making it environmentally friendly. Soft on the skin and virtually odourless. Not tested on animals."
We've used it and its true
sdc77
3,244
4,550
Weardale, Co Durham
We have a couple of bissells.. A large one we use for the carpets in the house (and van if req) and a, small green one which is perfect for upholstery
